OCZ Technology 256GB Vector Series SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 8F22WS00 Mfr#: VTR1-25SAT3-256G
The industry's best SSDs just got better.
Meet the storage expectations you didn't know you had. Engineered by longtime SSD experts, the OCZ Vector Series delivers a new level of untouchable performance, endurance, and reliability designed to empower your laptop or desktop to ba all it can be.
There is a faster, more responsive computing experience inside this box
Imagine faster file transfers, quicker boot ups, and a computer that responds the wy it was designed to and you've got yourself a Vector SSD. It's a 2.5" solid state powerhouse.
If you want lasting reliability, durability, and stealth operation, here is it.
With groundbreaking SSD quality and technology in every drive, the Vector Series is built to provide years of hard drive-humiliating performance that is second to no other storage solution.
  • Advanced uite of NAND flash management keeps your drive at higher sustained performance over the long term of maximum endurance
  • Excels in both incompressible and compressible data types such as multimedia, encrypted data, ZIP files and software
  • Cutting-edge controller technology delivers maximum performance and delivers unmatched endurance without compression or loss of usable capacity, rated for 20GB/day of host writes for 5 years
  • Bundled with a 3.6" desktop adapter bracket and an Acronis True Image cloning software registration key to easily transfer data from your old hard drive
  • Sleek alloy housing offers slimmer 7mm z-height for compatibility with the latest thinner form factor notebooks
Performance: 256GB
  • Sequential Read 550 MB/s
  • Sequential Write 530 MB/s
  • 4k Random Write 100,000 IOPS
  • 4k Random Read 95,000 IOPS
Technical Specifications
  • NAND Components Multi-Level Cell (MLC) NAND Flash
  • Interface Serial ATA (SATA) 6Gb/s (SATA III)
  • Form Factor 2.5-inch; 7mm height
  • Dimensions 99.7 (L) x 69.75 (W) x 7mm (H)
  • Operating & Storage Temperature 0°C ~ 55°C ; -45°C ~ 85°C
  • Controller Indilinx Barefoot 3
  • Performance Optimizations TRIM, Idle Time Garbage Collection, SMART Monitoring, ECC
  • Shock Resistance Up to 1500G/0.5ms
  • Operational Vibration 2.17Grms (7-800Hz)
  • Non-Operational Vibration 16.3Grms (20-2000Hz)
  • Certifications RoHS, CE, FCC, KCC, C-Tick, VCCI, & BSMI
  • Operating System Compatibility Windows, Linux, Mac OS X
  • Warranty 5-years Limited
  • More is more
    Advanced controller technology allows Vector to excel in high performance and deliver superior endurance without compression or loss of usable capacity. That means more space and more speed from your Vector SSD.
  • Thin is in
    With a sleek housing, Vector's slim z-height ensures compatibility with the latest thinner form factor notebooks. Alloy casing lends style that matches your taste for modern storage.
  • Faster performance for cost-effectiveness
    SSDs have 100x greater throughput and instantaneous access times for quicker boot ups, faster file transfers, and overall snappier performance than hard drives.
  • Less power, silent operation
    SSDs use significantly less wattage at peak load than hard drives, delivering longer battery life in notebooks, less power strain on system, and a cooler computing environment.
OCZ Vector Series - SSD - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
NAND Flash Memory Type
25nm multi-level cell (MLC)
2.5" Ultra Slim Line (in 3.5" carrier)
SATA 6Gb/s
Native Command Queuing (NCQ), TRIM support, Idle Time Garbage Collection, S.M.A.R.T., 28/1K bit BCH ECC
6.975 cm x 9.97 cm x 7 mm
115 g
5-year warranty
256 GB
SATA 6Gb/s
6.975 cm
9.97 cm
7 mm
115 g
Performance
Internal Data Rate
550 MBps (read) / 530 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
95000 IOPS
Reliability
MTBF
1,300,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 22 pin Serial ATA
Compatible Bay
2.5" Ultra Slim Line or 3.5" (with included bay adapter)
Power Consumption
2.25 watt (active) , 0.9 watt (idle)
Software Included
Acronis True Image HD
3.5-inch bay adapter
VCCI, C-Tick, BSMI, FCC, RoHS, KCC
Limited warranty - 5 years
55 °C
Shock Tolerance
1500 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 16.3 g @ 20-2000 Hz (non-operating)
Resources
The following resources are available for the OCZ Technology 256GB Vector Series SATA 6Gb/s 2.5" Solid State Drive
