OCZ DDR3 Triple Channel 6GB Kit
Quicklinx: 5J68WS00 Mfr#: OCZ3G1600LV6GK
The OCZ PC3-12800 triple-channel memory kit designed specifically for the impending Intel Core i7 processor'Intel X58 Express chipset. Optimized for the Core i7's triple channel mode, these kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won't inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ's Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation.
OCZ Gold XTC Triple Channel Kit - DDR3 - kit - 6 GB: 3 x 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
6 GB: 3 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL8 (8-8-8-24)
Gold layered Z3 XTC Heatspreader, unbuffered
Voltage
1.65 V
6 GB: 3 x 2 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL8 (8-8-8-24)
Non-ECC
Voltage
1.65 V
Compatible Slots
3 x memory - DIMM 240-pin
