The OCZ PC3-12800 triple-channel memory kit designed specifically for the impending Intel Core i7 processor'Intel X58 Express chipset. Optimized for the Core i7's triple channel mode, these kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won't inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ's Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation.
- OCZ Gold XTC Triple Channel Kit - DDR3 - kit - 6 GB: 3 x 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 6 GB: 3 x 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL8 (8-8-8-24)
- Gold layered Z3 XTC Heatspreader, unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty
- Capacity
- 6 GB: 3 x 2 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL8 (8-8-8-24)
- Non-ECC
- Voltage
- 1.65 V
- Compatible Slots
- 3 x memory - DIMM 240-pin
