OCZ DDR2 Dual Channel 4GB Kit
Quicklinx: 5J6CWS00 Mfr#: OCZ2G10664GK
The OCZ PC2-8500 Gold edition is optimized for the latest platforms and offers computer enthusiasts unparalleled performance and the piece of mind they are guaranteed to produce the world's fastest memory speeds within their personal desktop or gaming system. The DDR2-1066 Gold edition is the ultimate memory solution for contemporary PC applications and provides unsurpassed reliability and performance at a price point to suit all budgets.
The OCZ PC2-8500 Gold edition utilizes the OCZ heatspreader design. XTC (Xtreme Thermal Convection) heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of OCZ Gold series, the PC2-8500 edition is built with leading edge technology designed and qualified with special selection of premium components to maximize performance. At a heart-pounding DDR2-1066 combined with the high densities, the module turns out 5-6-6 timings with flawless performance and stability.
OCZ Gold series is 100% hand-tested to ensure compliance with stringent quality standards. With its ultra-fast performance, high quality and reliability, the OCZ PC2-8500 Gold edition is a perfect upgrade for memory-hungry platforms.
OCZ Gold Dual Channel Kit - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 1066 MHz / PC2-8500 - unbuffered
Memory kit
4 GB: 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC2-8500)
Latency Timings
CL5 (5-6-6-18)
Gold layered XTC heatspreader, OCZ EVP (Extended Voltage Protection), unbuffered
Voltage
2.1 V
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
1066 MHz (PC2-8500)
Latency Timings
CL5 (5-6-6-18)
Non-ECC
Voltage
2.1 V
Compatible Slots
2 x memory - DIMM 240-pin
