OCZ 240GB Vertex 460A SATA 6GB/s 2.5" Solid State Drive
Quicklinx: 9Z2KWS00 Mfr#: VTX460A-25SAT3-240G
OCZ introduces the Vertex 460A for those seeking a high-performance yet value-minded SSD. Combining OCZ's own controller design and superior flash, Vertex 460A keeps your system ahead of the game and delivers a faster, more responsive PC experience.
  • Storage for your multimedia, multitasking world
    The OCZ Vertex 460A Series delivers the performance, productivity, and energy efficiency you're craving from your system. Say goodbye to lag and get a computing experience worthy of your time.
  • Performance that matters
    Do you write a lot of data? Vertex 460A delivers leading write speeds that you won't get with any other solution. No fancy behind-the-scenes tricks, just pure storage performance.
  • Do more than just store
    Imagine faster file transfers, snappier boot ups, and system responsiveness that makes you wonder why you put up with that hard drive for so long.
  • Reliability and durability from the inside out
    With the quality technology built into every drive, the Vertex 460A Series is built to provide years of hard drive-humiliating performance. Ditch that spinning mechanical hard drive for some storage peace of mind.
OCZ Vertex 460A - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
A19nm multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 6Gb/s
Native Command Queuing (NCQ), shock resistant, TRIM support, OCZ Barefoot 3 M10 controller, S.M.A.R.T., 44/1K bit BCH ECC
69.75 mm x 99.7 mm x 7 mm
113 g
3-year warranty
240 GB
256-bit AES
2.5" x 1/8H
SATA 6Gb/s
69.75 mm
99.7 mm
7 mm
113 g
Performance
Internal Data Rate
540 MBps (read) / 525 MBps (write)
4KB Random Read
85000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
Power Consumption
3.45 Watt
Software Included
Acronis True Image HD
3.5-inch bay adapter
UL, VCCI, C-Tick, BSMI, FCC, KCC, WEEE
Limited warranty - 3 years
70 °C
