OCZ 240GB RevoDrive 350 Series PCIe Client Workstation SSD
Quicklinx: 9KH3WS00 Mfr#: RVD350-FHPX28-240G
Imagine the faster file transfers, snappier boot ups, and system responsiveness that make SSDs superior to hard drives, and then multiply that by 3x to achieve the incredible speeds of the PCIe-based RevoDrive 350. Free up the bandwidth and see the productivity potential your workstation or performance gaming system was missing for so long.
  • Break the bottleneck
  • Sophisticated feature-set
    With OCZ's Virtualized Controller Architecture (VCA) technology, the multi-controller RevoDrive 350 is seen by the host as a single drive to enable TRIM command support, SMART health monitoring, and easy firmware updates. Plus, it's bootable as a direct-attach device to launch applications in a snap.
  • Keep thermals in check
    That sleek casing isn't just for looks. RevoDrive 350 keeps its cool even during the most intensive applications or heavy multitasking with an improved alloy housing to effectively dissipate heat.
OCZ RevoDrive 350 - solid state drive - 240 GB - PCIe 2.0 x8
Solid state drive - internal
240 GB
Encryption Algorithm
128-bit AES
NAND Flash Memory Type
19nm multi-level cell (MLC)
PCIe 2.0 x8
TRIM support, Virtualized Controller Architecture (VCA) 2.0, Garbage Collection technology, SandForce SF-2282 controller, S.M.A.R.T., 128-bit AES
21.6 mm x 180.9 mm x 126.3 mm
310 g
3-year warranty
240 GB
128-bit AES
PCIe 2.0 x8
21.6 mm
180.9 mm
126.3 mm
310 g
Performance
Internal Data Rate
1000 MBps (read) / 950 MBps (write)
4KB Random Read
45000 IOPS
4KB Random Write
80000 IOPS
Reliability
MTBF
2,000,000 hours
Power Consumption
10.5 Watt (active) , 8 Watt (idle)
Linux, Microsoft Windows 7, Windows 8, Windows 8.1 (32/64 bits)
VCCI, C-Tick, BSMI, FCC, KCC, WEEE, cULus
Limited warranty - 3 years
55 °C
Shock Tolerance
500 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating)
Resources
The following resources are available for the OCZ 240GB RevoDrive 350 Series PCIe Client Workstation SSD
