NZXT Gamma Steel Black Midi Case
Quicklinx: 77STWS00 Mfr#: GAMA-001BK
The Gamma places a premium on effective airflow with 6 fan capability including dedicated VGA/CPU cooling and a unique front panel design that allows extra air to enter through the front. NZXT also includes pre-drilled water-cooling holes on the backplate and mounting holes for a dual radiator at the top. Gamma gives you everything you need for a meticulously clean build with punched motherboard holes and a turned HDD cage which keeps cabling as discrete as possible.
NZXT Classic Series GAMMA - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Baby-AT, ATX, microATX
System Cabinet Features
Meshed front panel
No power supply (ATX12V 2.0 / PS/2)
19 cm x 50.8 cm x 44.9 cm
6 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
7
Front Accessible Bays Qty
4
Fans
Rear: 1 x 12 cm - (1 installed) , Front: 1 x 12 cm - (0 installed) , Side: 2 x 12 cm - (0 installed) , Top: 2 x 14 cm - (0 installed)
Meshed front panel
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" x 1/2H , 7 (total) / 7 (free) x internal - 3.5" x 1/3H
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX12V 2.0 / PS/2
Max Supported Qty
1
19 cm
50.8 cm
44.9 cm
6 kg
