Nokia T20 10.4" 4GB 64GB WiFi - Blue
Quicklinx: GJYLWS00 Mfr#: F20RID1A012
Quality you can trust
Designed, built and tested with the same passion as all Nokia products, T20 brings that trusted quality to the big screen, so you have one less thing to worry about – even if your day gets a bit bumpier.
Do what you love for longer
A tablet with an all-day battery life - Nowadays, long battery life is a necessity. Nokia T20 comes with enough power to see you through up to 7 hours of online meetings, 10 hours of movies or 15 hours of surfing the web. Plus, faster charging means you can get back to what you were doing even quicker. From conference calls to science class, the power is yours.
Delight in every sight
See every detail with a 2K display - Nokia T20 makes light work of your day-to-day (and night) viewing with a captivating 2K screen. So, whether you’re viewing a work presentation on the go, or just relaxing at home with a movie, every detail will look fantastic. It's also low blue light certified...so it’s easier on the eyes.
Conquer any battlefield
Whether you’re playing games or multi-tasking across a few apps, you need a device that keeps up. Thankfully, Nokia T20 is boasts power to spare, with an octa-core chip ensuring a faster, more reliable user experience, even when pushed to the max. In short, there’s some serious power under this hood.
Immersed in sound
You need to be able to catch every word of every meeting, and when the day is done, enjoy your favourite entertainment with the stunning sound it deserves. Stereo speakers with OZO Playback deliver truly immersive listening experience - wherever you are.
  • Quality you can trust
    Designed, built and tested with the same passion as all Nokia products, T20 brings that trusted quality to the big screen, so you have one less thing to worry about - even if your day gets a bit bumpier.
  • Do what you love for longer
  • Delight in every sight
    Nokia T20 makes light work of your day-to-day (and night) viewing with a captivating 2K screen. So, whether you're viewing a work presentation on the go, or just relaxing at home with a movie, every detail will look fantastic. It's also low blue light certified... so it's easier on the eyes.
  • Conquer any battlefield
    Whether you're playing games or multitasking across a few apps, you need a device that keeps up. Thankfully, Nokia T20 is boasts power to spare, with an octa-core chip ensuring a faster, more reliable user experience, even when pushed to the max. In short, there's some serious power under this hood.
  • Immersed in sound
    You need to be able to catch every word of every meeting, and when the day is done, enjoy your favorite entertainment with the stunning sound it deserves. Stereo speakers with OZO Playback deliver truly immersive listening experience - wherever you are.
  • Take your tablet anywhere
    Protect your Nokia T20 against drops and scratches with purpose-built rugged accessories.
Nokia T20 - tablet - Android 11 - 64 GB - 10.4"
Tablet
Operating System
Android 11
Display
10.4" - 1200 x 2000 - Multi-Touch
Unisoc Tiger T610 (8-core)
Processor Clock Speed
1.8 GHz
Storage
64 GB
RAM
4 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Rear Camera
8 Megapixel focus: automatic
Front Camera
5 Megapixel
Radio Tuner Type
FM radio
Security Devices
Face recognition
15.75 cm x 0.78 cm x 24.76 cm
465 g
Deep ocean
1.35 W/kg (body)
Tablet
Operating System
Android 11
Display
10.4"
Resolution
1200 x 2000
Touchscreen
Multi-Touch
Image Brightness
400 cd/m²
In-cell touch technology, toughened glass, brightness boost
Unisoc Tiger T610
1.8 GHz
Number of Cores
8-core
Storage
64 GB
RAM
4 GB
Max Supported Capacity
512 GB
Communications
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
Light Source
LED flash
Front Camera
Sensor Resolution
5 Megapixel
Multimedia
Radio Tuner Type
FM radio
Audio
Two microphones, stereo speakers with amplifier
Input Device
Security Devices
Face recognition
Software
Preloaded Software
Google Kids Space, Google Entertainment Space
Expansion and Connectivity
Expansion Slots
1 x microSDXC
USB-C/USB 2.0 ¦ Headphones mini jack (3.5mm)
8200 mAh
Deep ocean
Case Material
Sandblasted aluminium
Face Unlock
SIM card ejection tool, 10W charger
IP52, SGS Low Blue Light Certification
1.35 W/kg (body)
15.75 cm
0.78 cm
24.76 cm
465 g
