Nokia DC-19 Portable Battery - Cyan
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9SWLWS00 Mfr#: 02738R2
Running low? Simply plug the DC-19 into your phone and keep on browsing, chatting and socializing with this no-hassle portable charger. Fill your smartphone's battery to the brim with a blast from the DC-19 portable charger. It carries so much juice that even after a full top-up, there's more to give.
  • Power up on the go
  • Super charger
  • Quick charge
    The power hits your phone battery fast, so there's no waiting around. And you'll always know what's left in your charger's tank with at-a-glance LED energy indicators.
  • Get connected
    Recharge any micro-USB device and then refill the DC-19 using a USB power supply.
Nokia DC-19 power bank - Li-Ion - USB
Power bank
Mobile phone
9.95 cm
Diameter
2.54 cm
78 g
Cyan
Output Connector Type
USB
5 V
Lithium Ion
Cables
USB cable - 25 cm
Lumia 540 Dual SIM; Nokia 225, 225 Dual SIM, X Dual SIM, XL Dual SIM; Asha 501, 501 Dual SIM; Lumia 1320, 520, 630, 630 Dual SIM, 635, 730 Dual SIM, 925, 930, Icon
Power bank
Mobile phone
9.95 cm
Diameter
2.54 cm
78 g
Enclosure Colour
Cyan
5 V
Input Connectors
5 pin Micro-USB Type B
Output connectors
4 pin USB Type A
Lithium Ion
Voltage Provided
3.7 V
Recharge Time
200 min
Power level indicator button, battery level indicator
USB cable - 25 cm
Microsoft Lumia 540 Dual SIM , Nokia 225, 225 Dual SIM, X Dual SIM, XL Dual SIM , Nokia Asha 501, 501 Dual SIM , Nokia Lumia 1320, 520, 630, 630 Dual SIM, 635, 730 Dual SIM, 925, 930, Icon
