Discover the power of AI with Nokia 2.3. It lasts up to 2 days with Adaptive Battery technology, takes epic shots with AI imaging – even in low-light – and unlocks with a glance. Bring great stories to life with the impressive 6.2" HD+ 19:9 screen. Plus, it’s ready for Android 10 and beyond so you can look forward to 2 years of software upgrades and 3 years of monthly security updates.
Be entertained all day
Get lost in your favorite series and movies for longer with the AI-assisted 2-day battery life. And bring great stories to life with the large 6.2" HD+ 19:9 screen.
Designed with you in mind
Nokia 2.3 looks good and feels strong. And with biometric face unlock, its password is as unique as you – one glance, and you’re in.
Ready for Android 10 and beyond
A phone that just keeps getting better. Nokia 2.3 is certified Android One, which means you get a pure software experience with a streamlined interface and no bloatware. Plus, with 2 years of software upgrades and 3 years of monthly security updates, it will stay safe and act as good as new.
A little help wherever you go
The Google Assistant Button is there to keep up with your fast-paced life. Ask questions, see your schedule or check the traffic. Your Assistant learns and adapts with every use – so you can do more with your life, by doing less with your phone.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Nokia 2.3 looks good and feels strong. And with biometric face unlock, its password is as unique as you - one glance, and you're in. -
The Google Assistant Button is there to keep up with your fast-paced life. Ask questions, see your schedule or cheque the traffic. Your Assistant learns and adapts with every use - so you can do more with your life, by doing less with your phone.
- Nokia 2.3 - Android One - charcoal - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- - 6.2" - 19:9
- FM radio
- Processor
- MediaTek Helio A22
- Memory
- RAM 2 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 13 Megapixel - f/2.2 - focus: automatic
- Second Camera
- 2 Megapixel - depth sensor
- Front Camera
- 5 Megapixel f/2.4
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- Wi-Fi, Bluetooth
- Security Devices
- Face recognition
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Charcoal
- 75.41 mm x 8.68 mm x 157.69 mm
- 183 g
- Specific Absorption Rate (SAR)
- 0.41 W/kg (head) , 1.4 W/kg (body)
- Product Type
- Smartphone
- Form Factor
- Touch
- Integrated Components
- FM radio
- 75.41 mm
- 8.68 mm
- 157.69 mm
- 183 g
- Body Colour
- Charcoal
- Body Material
- Polymer, die-cast metal
- SAR Value
- 1.4 W/kg (body), 0.41 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS, A-GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- IEEE 802.11b/g/n, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor
- Security Devices
- Face recognition
- Additional Features
- Face Unlock, Google Assistant Button, 3 years of Security Updates
- RAM
- 2 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
Main Camera
- Sensor Resolution
- 13 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Special Effects
- Bokeh effect
- Camera Modes
- Low-light shots, portrait mode
- Light Source
- LED flash
- Background blur
Second Camera
- Sensor Resolution
- 2 Megapixel
- Sensor Type
- Depth sensor
Display
- Diagonal Size
- 6.2"
- Display Format
- HD+
- Aspect Ratio
- 19:9
- In-Cell Display Technology
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 4000 mAh
- Included Accessories
- USB cable, power adapter, SIM card removal tool
