Nokia 105 4G
Nokia 105 4G
Quicklinx: GP38WS00 Mfr#: 16VEGB01A02
With Nokia 105 4G, keeping in touch with family and friends has never been easier - or more rewarding. Built with 4G VoLTE capabilities, calls are so crisp and clear that those close to you will feel even closer. And when you're not calling, listening to FM radio and playing games will keep you smiling through your down time?- especially as its zoomed menus and Readout text-to-speech function makes navigating your way around the phone as easy as can be.
  • Closer connections
    Phones are a great way to connect to family and friends, wherever they are. That's why Nokia 105 4G is 4G VoLTE ready with next generation voice capabilities and HD voice calling, so when you speak to someone, the connection sounds even closer.
  • Easier to use
    Zoomed menus and icons make navigation simple to use, and the Readout feature talks you through what you're doing, as you're doing it - making this possibly the most helpful phone you'll ever use.
  • Classic quality never looked so good
    Built to last and designed to impress, Nokia 105 4G comes with a long battery life and is sleek enough to slip into your pocket. But with three, stylish colors to choose from - Blue, Red and Black - hiding it away will be the last thing you want to do.
  • All your favorite features in one phone
    Nokia 105 4G is more than just a phone. It has both a wireless and wired FM radio, a bright torch, and comes with a bunch of games. And, thanks to 4G, it connects to the Internet in an instant. All of this, in the palm of your hand.
Nokia 105 4G (2021) - black - 4G feature phone - 128 MB - GSM
4G feature phone
Manufacturer Model Number
TA-1378
Display
160 x 120 pixels - 1.8"
FM radio, LED flashlight
Unisoc T107
RAM 48 MB / 128 MB
Service Provider
Not specified
Bar
SIM Card
Dual-SIM - nano SIM
Messaging Services
SMS
Connectors
3.5 mm headset jack, Micro-USB
50 mm x 14.5 mm x 121 mm
80.2 g
1.321 W/kg (head) , 1.731 W/kg (body)
Feature phone
TA-1378
Bar
Integrated Components
50 mm
14.5 mm
121 mm
80.2 g
Body Colour
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Messaging & Internet
Messaging Services
SMS
Communications
Data Transmission
LTE, VoLTE
2G Band
900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 5, Band 8
3G UMTS Frequency
2100, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD
Unisoc
Processor Number
T107
RAM
48 MB
Internal Memory Capacity
128 MB
Display
Diagonal Size
1.8"
Display Resolution
160 x 120 pixels
Display Format
QQVGA
Connector Type
Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B
1020 mAh
Run Time Details
Talk (dual SIM 3G): up to 360 min , Talk (dual SIM 4G): up to 300 min , Talk (dual SIM GSM): up to 960 min , Talk (single SIM 3G): up to 360 min , Talk (single SIM 4G): up to 300 min , Talk (single SIM GSM): up to 960 min , Standby (dual SIM 3G): up to 264 hrs , Standby (dual SIM 4G): up to 288 hrs , Standby (dual SIM GSM): up to 312 hrs , Standby (single SIM 3G): up to 336 hrs , Standby (single SIM 4G): up to 336 hrs , Standby (single SIM GSM): up to 432 hrs , Playback: up to 36 hrs
Headset, micro-USB charger
