Nintendo Switch OLED White - Grade A
Quicklinx: HD02WS00 Mfr#: 400018124
30 left in stock
£199.17 ex VAT
£239.00 inc VAT
Express delivery Delivered on Wednesday
Grade A Returned Device
Want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Re-sealed, original packaging
Nintendo Switch – OLED Model is the newest addition to the Nintendo Switch family of consoles. It includes a 7-inch vibrant OLED screen, a wide adjustable stand for tabletop mode, a new dock with a wired LAN port for use in TV mode, 64 GB of internal storage, and enhanced audio for handheld and tabletop play. Just like Nintendo Switch, play on a TV, share the detachable Joy-Con controllers for multiplayer fun, or take the console on the go to enjoy its play-anywhere versatility.
  • Meet the new member of the Nintendo Switch family
    The system features a vibrant 7-inch OLED screen, a wide adjustable stand, a dock with a wired LAN port, 64 GB of internal storage, and enhanced audio.
  • 7-inch OLED screen
    Feast your eyes on vivid colors and crisp contrast when you play on-the-go.
  • Wide, adjustable stand
    Flip out the sturdy stand for easy viewing in Tabletop mode.
  • Find your best angle
    Adjust the stand to find the optimal viewing angle - perfect for a quick multiplayer game with a buddy.
  • Built-in wired LAN port
    Connect online using the dock's LAN port when playing in TV mode.
  • 64 GB internal storage
    Save games to your system with 64 GB of internal storage.
  • Enhanced audio
    Enjoy enhanced audio from the system's onboard speakers.
  • Three modes in one
    Nintendo Switch and Nintendo Switch (OLED model) systems are designed to fit your life, transforming from home console to portable system in a snap!
Nintendo Switch OLED - Game console - white
Game console
Video
1080p
Display
7" colour - touch screen
Controller
Joy-Con (L) white - wireless
Second Controller
Joy-Con (R) white - wireless
Sensors
Accelerometer, ambient light sensor, gyro sensor
Media
Flash memory card, Nintendo Switch Game Card
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Network
Fast Ethernet, Wi-Fi, Bluetooth 4.1
Lithium Ion
White
AC power adapter, Nintendo Joy-Con Grip, Nintendo Switch Dock, 2 Joy-Con Wrist Straps
Game console
Media
NVIDIA
Flash Memory
64 GB
Sound
Speakers
Network
Fast Ethernet, 802.11a/b/g/n/ac, Bluetooth 4.1
Amiibo support
Parental Control Capability
White
Display
OLED display 7" colour
Touch Screen
Controller
Controls
L Button, directional buttons, Minus button, SYNC button, ZL button, Left stick, Capture button, SL button, SR button, Release button
Vibration-feedback, LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery
Second Controller
Controls
A button, B button, R Button, Plus button, Home button, X button, Y button, SYNC button, ZR button, Right stick, SL button, SR button, Release button
Vibration-feedback, Near Field Communication (NFC), LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery, IR Motion camera
Video Output
TV Connection
HDMI
Resolution
1080p
Connector Type
USB , Audio output , LAN
Slots
1 x Nintendo Switch Game Card slot
Rechargeable Lithium Ion
Sensors
Accessories (1)
HD02 Nintendo AC Adapter In Stock £21.07
Controllers (1)
HD02 Nintendo Joy-Con Pair (Neon Green/Pink) In Stock £49.17
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HD02 050655
Condition: Customer return - item has been used and shows signs of use/ slight scratch in middle of screen / some wear and tear
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £143.55
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Handheld game console
Platform: Nintendo Switch
Brand: Nintendo
Stock Status: While stocks last
Stock Status: Used Stock
Stock Status: Clearance
