Grade A Returned Device
Want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
Nintendo Switch – OLED Model is the newest addition to the Nintendo Switch family of consoles. It includes a 7-inch vibrant OLED screen, a wide adjustable stand for tabletop mode, a new dock with a wired LAN port for use in TV mode, 64 GB of internal storage, and enhanced audio for handheld and tabletop play. Just like Nintendo Switch, play on a TV, share the detachable Joy-Con controllers for multiplayer fun, or take the console on the go to enjoy its play-anywhere versatility.
Meet the new member of the Nintendo Switch family
The system features a vibrant 7-inch OLED screen, a wide adjustable stand, a dock with a wired LAN port, 64 GB of internal storage, and enhanced audio. -
7-inch OLED screen
Feast your eyes on vivid colors and crisp contrast when you play on-the-go. -
Wide, adjustable stand
Flip out the sturdy stand for easy viewing in Tabletop mode. -
Find your best angle
Adjust the stand to find the optimal viewing angle - perfect for a quick multiplayer game with a buddy. -
Built-in wired LAN port
Connect online using the dock's LAN port when playing in TV mode. -
64 GB internal storage
Save games to your system with 64 GB of internal storage. -
Enhanced audio
Enjoy enhanced audio from the system's onboard speakers. -
Three modes in one
Nintendo Switch and Nintendo Switch (OLED model) systems are designed to fit your life, transforming from home console to portable system in a snap!
- Nintendo Switch OLED - Game console - white
- Product Type
- Game console
- Video
- 1080p
- Display
- 7" colour - touch screen
- Controller
- Joy-Con (L) white - wireless
- Second Controller
- Joy-Con (R) white - wireless
- Sensors
- Accelerometer, ambient light sensor, gyro sensor
- Media
- Flash memory card, Nintendo Switch Game Card
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Network
- Fast Ethernet, Wi-Fi, Bluetooth 4.1
- Battery
- Lithium Ion
- White
- Included Accessories
- AC power adapter, Nintendo Joy-Con Grip, Nintendo Switch Dock, 2 Joy-Con Wrist Straps
- Product Type
- Game console
- Media
- Processor
- NVIDIA
- Flash Memory
- 64 GB
- Sound
- Speakers
- Network
- Fast Ethernet, 802.11a/b/g/n/ac, Bluetooth 4.1
- Amiibo support
- Parental Control Capability
- White
Display
- OLED display 7" colour
- Touch Screen
Controller
- Controls
- L Button, directional buttons, Minus button, SYNC button, ZL button, Left stick, Capture button, SL button, SR button, Release button
- Vibration-feedback, LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery
Second Controller
- Controls
- A button, B button, R Button, Plus button, Home button, X button, Y button, SYNC button, ZR button, Right stick, SL button, SR button, Release button
- Vibration-feedback, Near Field Communication (NFC), LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery, IR Motion camera
Video Output
- TV Connection
- HDMI
- Resolution
- 1080p
- Connector Type
- USB , Audio output , LAN
- Slots
- 1 x Nintendo Switch Game Card slot
- Battery
- Rechargeable Lithium Ion
- Sensors
Nintendo Joy-Con Pair (Neon Green/Pink) | In Stock | £49.17 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HD02 050655 Condition: Customer return - item has been used and shows signs of use/ slight scratch in middle of screen / some wear and tear |
£138.60 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
