Nintendo Switch OLED Mario Red Edition
Quicklinx: HDHDWS00 Mfr#: 10011773
Sorry but this product has been discontinued.
View used stock
Featuring a vibrant 7-inch OLED screen with vivid colours
Nintendo Switch – OLED Model is the newest addition to the Nintendo Switch family of consoles. It includes a 7-inch vibrant OLED screen, a wide adjustable stand for tabletop mode, a new dock with a wired LAN port for use in TV mode, 64 GB of internal storage, and enhanced audio for handheld and tabletop play. Just like Nintendo Switch, play on a TV, share the detachable Joy-Con controllers for multiplayer fun, or take the console on the go to enjoy its play-anywhere versatility.
Three play modes
Nintendo Switch can transform to suit your situation, so you can play the games you want, no matter how busy your life may be. It's a new era where you don't have to adjust your lifestyle to play games — instead, your console adjusts to fit around your lifestyle.
TV mode - Gather around a big screen and enjoy gaming with a crowd. Dock your Nintendo Switch to enjoy HD gaming on your TV.
Tabletop mode - Share the screen, share the fun. Flip the stand to share the screen, then share the fun with a multiplayer game.
Handheld mode - Carry around a large, beautiful display anywhere you go. Pick it up and play with the Joy-Con controllers attached
  • Meet the new member of the Nintendo Switch family
    The system features a vibrant 7-inch OLED screen, a wide adjustable stand, a dock with a wired LAN port, 64 GB of internal storage, and enhanced audio.
  • 7-inch OLED screen
    Feast your eyes on vivid colors and crisp contrast when you play on-the-go.
  • Wide, adjustable stand
    Flip out the sturdy stand for easy viewing in Tabletop mode.
  • Find your best angle
    Adjust the stand to find the optimal viewing angle - perfect for a quick multiplayer game with a buddy.
  • Built-in wired LAN port
    Connect online using the dock's LAN port when playing in TV mode.
  • 64 GB internal storage
    Save games to your system with 64 GB of internal storage.
  • Enhanced audio
    Enjoy enhanced audio from the system's onboard speakers.
  • Three modes in one
    Nintendo Switch and Nintendo Switch (OLED model) systems are designed to fit your life, transforming from home console to portable system in a snap!
Nintendo Switch OLED - Mario Red Edition - Game console - Mario Red
Game console
Video
1080p
Display
7" colour - 1280 x 720 - touch screen (Multi-Touch)
Controller
Joy-Con (L) Mario Red - wireless
Second Controller
Joy-Con (R) Mario Red - wireless
Sensors
Accelerometer, ambient light sensor, gyro sensor
Media
Flash memory card, Nintendo Switch Game Card
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Network
Wi-Fi, Bluetooth 4.1, Fast Ethernet
Lithium Ion - 4310 mAh
Mario Red
24.2 cm x 1.39 cm x 10.2 cm
422 g
Nintendo Switch Dock, Joy-Con (L), Joy-Con (R), 2 Joy-Con Wrist Straps, Nintendo Joy-Con Grip, AC power adapter, HDMI cable
Game console
Media
NVIDIA
Flash Memory
64 GB
Sound
Speakers
Network
802.11a/b/g/n/ac, Bluetooth 4.1, Fast Ethernet
Amiibo support
Parental Control Capability
24.2 cm
1.39 cm
10.2 cm
422 g
Mario Red
Display
OLED display 7" colour
Resolution
1280 x 720
Touch Screen
Yes (Multi-Touch)
Controller
Controls
L Button, directional buttons, Minus button, SYNC button, ZL button, Left stick, Capture button, SL button, SR button, Release button
Vibration-feedback, LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery
Second Controller
Controls
A button, B button, R Button, Plus button, Home button, X button, Y button, SYNC button, ZR button, Right stick, SL button, SR button, Release button
Vibration-feedback, Near Field Communication (NFC), LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery, IR Motion camera
Video Output
TV Connection
HDMI
Resolution
1080p
Connector Type
USB , Audio output , LAN
Slots
1 x Nintendo Switch Game Card slot
Rechargeable Lithium Ion - 4310 mAh
Run Time (Up To)
9 hour(s)
Sensors
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HDHD 051235
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £206.95
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Game console
Platform: Nintendo Switch OLED
Brand: Nintendo
Stock Status: Used Stock
Stock Status: Clearance
