Featuring a vibrant 7-inch OLED screen with vivid colours
Nintendo Switch – OLED Model is the newest addition to the Nintendo Switch family of consoles. It includes a 7-inch vibrant OLED screen, a wide adjustable stand for tabletop mode, a new dock with a wired LAN port for use in TV mode, 64 GB of internal storage, and enhanced audio for handheld and tabletop play. Just like Nintendo Switch, play on a TV, share the detachable Joy-Con controllers for multiplayer fun, or take the console on the go to enjoy its play-anywhere versatility.
Three play modes
Nintendo Switch can transform to suit your situation, so you can play the games you want, no matter how busy your life may be. It's a new era where you don't have to adjust your lifestyle to play games — instead, your console adjusts to fit around your lifestyle.
TV mode - Gather around a big screen and enjoy gaming with a crowd. Dock your Nintendo Switch to enjoy HD gaming on your TV.
Tabletop mode - Share the screen, share the fun. Flip the stand to share the screen, then share the fun with a multiplayer game.
Handheld mode - Carry around a large, beautiful display anywhere you go. Pick it up and play with the Joy-Con controllers attached
Meet the new member of the Nintendo Switch family
The system features a vibrant 7-inch OLED screen, a wide adjustable stand, a dock with a wired LAN port, 64 GB of internal storage, and enhanced audio. -
7-inch OLED screen
Feast your eyes on vivid colors and crisp contrast when you play on-the-go. -
Wide, adjustable stand
Flip out the sturdy stand for easy viewing in Tabletop mode. -
Find your best angle
Adjust the stand to find the optimal viewing angle - perfect for a quick multiplayer game with a buddy. -
Built-in wired LAN port
Connect online using the dock's LAN port when playing in TV mode. -
64 GB internal storage
Save games to your system with 64 GB of internal storage. -
Enhanced audio
Enjoy enhanced audio from the system's onboard speakers. -
Three modes in one
Nintendo Switch and Nintendo Switch (OLED model) systems are designed to fit your life, transforming from home console to portable system in a snap!
- Nintendo Switch OLED - Mario Red Edition - Game console - Mario Red
- Product Type
- Game console
- Video
- 1080p
- Display
- 7" colour - 1280 x 720 - touch screen (Multi-Touch)
- Controller
- Joy-Con (L) Mario Red - wireless
- Second Controller
- Joy-Con (R) Mario Red - wireless
- Sensors
- Accelerometer, ambient light sensor, gyro sensor
- Media
- Flash memory card, Nintendo Switch Game Card
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Network
- Wi-Fi, Bluetooth 4.1, Fast Ethernet
- Battery
- Lithium Ion - 4310 mAh
- Mario Red
- 24.2 cm x 1.39 cm x 10.2 cm
- 422 g
- Included Accessories
- Nintendo Switch Dock, Joy-Con (L), Joy-Con (R), 2 Joy-Con Wrist Straps, Nintendo Joy-Con Grip, AC power adapter, HDMI cable
- Product Type
- Game console
- Media
- Processor
- NVIDIA
- Flash Memory
- 64 GB
- Sound
- Speakers
- Network
- 802.11a/b/g/n/ac, Bluetooth 4.1, Fast Ethernet
- Amiibo support
- Parental Control Capability
- 24.2 cm
- 1.39 cm
- 10.2 cm
- 422 g
- Mario Red
Display
- OLED display 7" colour
- Resolution
- 1280 x 720
- Touch Screen
- Yes (Multi-Touch)
Controller
- Controls
- L Button, directional buttons, Minus button, SYNC button, ZL button, Left stick, Capture button, SL button, SR button, Release button
- Vibration-feedback, LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery
Second Controller
- Controls
- A button, B button, R Button, Plus button, Home button, X button, Y button, SYNC button, ZR button, Right stick, SL button, SR button, Release button
- Vibration-feedback, Near Field Communication (NFC), LED indicator, Bluetooth technology, accelerometer, gyro sensor, built-in 525 mAh battery, IR Motion camera
Video Output
- TV Connection
- HDMI
- Resolution
- 1080p
- Connector Type
- USB , Audio output , LAN
- Slots
- 1 x Nintendo Switch Game Card slot
- Battery
- Rechargeable Lithium Ion - 4310 mAh
- Run Time (Up To)
- 9 hour(s)
- Sensors
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HDHD 051235 Condition: Customer return - item has been repaired under warranty by the manufacturer |
£240.52 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
