Nintendo Switch Lite is a compact, lightweight Nintendo Switch system dedicated to handheld play. With a built-in +Control Pad and a sleek, unibody design, it's great for on-the-go gaming. Nintendo Switch Lite is compatible with the robust library of Nintendo Switch games that support handheld mode. If you're looking for a gaming system all your own, Nintendo Switch Lite is ready to hit the road whenever you are.
Compact and lightweight
With its light, sleek design, this system is ready to hit the road whenever you are. -
Built-in controllers
Controllers are built right into the system for handheld play, and the left side sports a +Control Pad. -
Compatible games
The Nintendo Switch Lite system plays the library of Nintendo Switch games that work in handheld mode.
- Nintendo Switch Lite - handheld game console - grey
- Product Type
- Handheld game console
- Display
- 5.5" colour - 1280 x 720 - touch screen
- Sensors
- Accelerometer, gyro sensor
- Media
- Flash memory card, Nintendo Switch Game Card
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
- Network
- Near Field Communication (NFC), Wi-Fi, Bluetooth 4.1
- Battery
- Lithium Ion - 3570 mAh
- Grey
- 20.8 cm x 1.39 cm x 9.11 cm
- 275 g
- Included Accessories
- AC power adapter
- Product Type
- Media
- Processor
- NVIDIA Tegra
- Flash Memory
- 32 GB
- Sound
- Speakers
- Network
- Near Field Communication (NFC), 802.11a/b/g/n/ac, Bluetooth 4.1
- Volume control
- Parental Control Capability
- 20.8 cm
- 1.39 cm
- 9.11 cm
- 275 g
- Grey
Display
- LCD display 5.5" colour
- Resolution
- 1280 x 720
- Touch Screen
Controller
- Controls
- A button, B button, L Button, R Button, cross control pad, Minus button, Plus button, Home button, X button, Y button, ZL button, ZR button, Right stick, Left stick, Capture button
- Connector Type
- USB , Audio line-out
- Slots
- 1 x Nintendo Switch Game Card slot
- Battery
- Rechargeable Lithium Ion - 3570 mAh
- Run Time (Up To)
- 7 hour(s)
- Sensors
- AC power adapter
