Nintendo Switch Lite Coral
Quicklinx: FZ1VWS00 Mfr#: 10289411
Colours:
Nintendo Switch Lite is a compact, lightweight Nintendo Switch system dedicated to handheld play. With a built-in +Control Pad and a sleek, unibody design, it's great for on-the-go gaming. Nintendo Switch Lite is compatible with the robust library of Nintendo Switch games that support handheld mode. If you're looking for a gaming system all your own, Nintendo Switch Lite is ready to hit the road whenever you are.
  • Compact and lightweight
    With its light, sleek design, this system is ready to hit the road whenever you are.
  • Built-in controllers
    Controllers are built right into the system for handheld play, and the left side sports a +Control Pad.
  • Compatible games
    The Nintendo Switch Lite system plays the library of Nintendo Switch games that work in handheld mode.
Nintendo Switch Lite - handheld game console - Coral
Handheld game console
Display
5.5" colour - 1280 x 720 - touch screen
Sensors
Accelerometer, gyro sensor
Media
Flash memory card, Nintendo Switch Game Card
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Network
Near Field Communication (NFC), Wi-Fi, Bluetooth 4.1
Lithium Ion - 3570 mAh
Coral
20.8 cm x 1.39 cm x 9.11 cm
275 g
AC power adapter
Media
NVIDIA Tegra
Flash Memory
32 GB
Sound
Speakers
Network
Near Field Communication (NFC), 802.11a/b/g/n/ac, Bluetooth 4.1
Volume control
Parental Control Capability
20.8 cm
1.39 cm
9.11 cm
275 g
Coral
Display
LCD display 5.5" colour
Resolution
1280 x 720
Touch Screen
Controller
Controls
A button, B button, L Button, R Button, cross control pad, Minus button, Plus button, Home button, X button, Y button, ZL button, ZR button, Right stick, Left stick, Capture button
Connector Type
USB , Audio line-out
Slots
1 x Nintendo Switch Game Card slot
Rechargeable Lithium Ion - 3570 mAh
Run Time (Up To)
7 hour(s)
Sensors
AC power adapter
