Nintendo Switch - Neon Red Joy-Con (L) and Neon Blue Joy-Con (R) Controller Set
Quicklinx: CNMLWS00 Mfr#: 2510166
Type: Joy-Con
Wired / Wireless: Wireless
Compatibility: Nintendo Switch
£49.17 ex VAT
£59.00 inc VAT
Express delivery Order within the next 16 hours for delivery on Monday
A Neon Red Joy-Con (L) and Neon Blue Joy-Con (R) together make up a set of Joy-Con controllers. Pick up an extra set of Joy-Con controllers to open new kinds of gaming possibilities!
The right Joy-Con Controller includes an NFC touchpoint to unlock amiibo functionality.
This set includes two neon Joy-Con Controllers (Left and Right) and two black Nintendo Switch Joy-Con Controller Straps.
Release Date: 03 March 2017
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CNML 048276
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £20.92
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Joy-Con
Brand: Nintendo
Stock Status: Used Stock
