Nikon D7100 - DSLR - 24.1 Mpix - 5.8x optical zoom - AF-S DX 18-105mm lens
Quicklinx: 8KNRWS00 Mfr#: VBA360K001
  • SDHC Memory Card
Give your photographic passions an adrenaline injection with the exceptionally powerful D7100.
Surprisingly light and compact for a feature-packed and durable body, it delivers superior DX performance to take your photography to the next level. By not employing an optical low pass filter (OLPF), the D7100 makes the most of its 24.1-megapixel DX-format CMOS sensor to sharply capture even the finest textures in crisp high resolution. Its 51-point autofocus (AF) system offers you rapid and ultra accurate image capture at professional level. Weather and dust resistant, with magnesium alloy top and rear covers, this high-spec D-SLR shoots continuously at 6 fps, gives an extra telephoto effect with innovative 1.3x crop function and has ISO sensitivity of 100-6400, bringing superb results in poorly-lit environments or fast-moving action.
Shoot with viewfinder or Live View, apply special effects in real time for stills or Full HD movies, and send images wirelessly* to your smart device for sharing on social media - the D7100 puts exceptional control in your hands, wherever you go, whatever you do.
24.1-megapixel DX format CMOS sensor, with no OLPF
For extreme image sharpness on even the finest details.
EXPEED 3 image processor
For high speed operation, vibrant color reproduction and enhanced noise reduction.
ISO sensitivity of 100-6400, extendable to 25600
For exceptional low light performance.
Professional-level AF system
Utilizing 51 focus points, 15 of which are cross-type, for rapid and precise autofocus.
6 fps continuous shooting
To ensure you always capture that fast action shot.
1.3x crop function, expanding the possibilities of DX format
With extra telephoto effect, faster speed (up to 7 fps) and extra wide AF coverage.
2,016-pixel RGB metering sensor with Scene Recognition
Highly accurate metering for exact exposures; optimizing auto exposure (AE), autofocus (AF) and auto white balance (AWB) for supreme accuracy.
Full HD D-Movie
1920x1080 at 24p/25p/30p up to 50i/60i for smooth movie recording.
High performance viewfinder
With approximately 100% frame coverage and 0.94x magnification.
High-intensity LCD monitor
Offers an 8cm/3.2in 1229k-dot wide-angle view.
Conveniently portable
Powerful features packed into a compact body weighing just 675g.
Durable body with magnesium alloy covers
Sealed for dust and weather resistance.
Dual SD memory card slots
Allow overflow and backup recording or set to record RAW and J-PEG individually.
Accessible usability functions
Improved `i' button and Spot White Balance for quick and precise white balance setting in Live View.
Active D-Lighting (ADL)
Retains details in highlights and shadows for well-balanced images.
High Dynamic Range (HDR)
Combines two shots within a single shutter release to create detailed images of high contrast scenes.
Effects Mode
Allows selected effects to be applied to both stills and movies in Live View.
Wireless connectivity
Compatible with WU-1a Mobile Adapter.
NIKKOR lenses
With acclaimed NIKKOR lenses you can take full advantage of the camera's 24.1 megapixels and 1.3x crop mode to create exceptional images and enjoy the portability of DX lenses.
Remote operation
Take control of your wireless shooting with the WR-R10 wireless transceiver and the WR-T10 wireless transmitter, or advance by controlling your camera settings with the WR-1 (none of these included).
  • Capture every detail true to life
    The D7100 marks an exciting advancement in image quality for high-resolution DX-format cameras. Nikon specially designed its 24.1-megapixel DX-format CMOS sensor without using an optical low pass filter (OLPF), resulting in the purest, sharpest images using D7100's DX-format CMOS sensor.
  • Speed and precision in harmony
    When the action speeds up, fire a blazing fast 6 frames per second continuously for up to 100 shots. Building on the acclaimed autofocus system from the D300s, the D7100 uses 51 focus points, including 15 cross-type sensors for detecting both vertical and horizontal contrast variations, to achieve fast, precise focus. The central cross-type sensor works all the way down to f/8, a huge advantage when using compatible teleconverters. At the same time, a highly accurate 2016-pixel RGB sensor evaluates every scene, taking into account brightness, contrast, subject distance and color, for spot-on auto operations like Face-Priority and full-time autofocus during video capture.
  • Create movies that amaze
    With full-time autofocus and manual exposure control during video recording, a built-in stereo microphone and an external stereo microphone jack, headphone and HDMI jacks, the D7100 achieves exceptional cinematic reproduction and quality. Dual SD card slots give you additional recording time, and a 60i function enables smooth playback on HDTVs or external monitors.
Nikon D7100 - digital camera AF-S DX 18-105mm lens
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
Dual SD card
Image Processor
EXPEED 3
Sensor Resolution
24.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
5.8 x zoom lens - 18 - 105 mm - f/3.5-5.6 G Nikon AF-S DX ED VR
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Image Stabiliser
Optical
Camera Flash
Pop-up flash
Viewfinder
Optical - fixed eye-level pentaprism
Display
LCD display - 3.2"
Supported Battery
1 x Li-ion rechargeable battery ( included )
AV Interfaces
HDMI
13.55 cm x 7.6 cm x 10.65 cm
675 g
Lens Included
Sensor Resolution
24.1 Megapixel
Optical Sensor Type
CMOS
Total Pixels
24,710,000 pixels
Effective Sensor Resolution
24,100,000 pixels
Optical Sensor Size
15.6 x 23.5mm
Field of View Crop Factor
1.5
Sensor Dust Reduction
Sensor Features
Self Cleaning Sensor Unit
Optical Zoom
5.8 x
Image Processor
EXPEED 3
Image Stabiliser
Optical
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
51
AE/AF Control
Dynamic-area AF, 3D-tracking AF, Auto-area AF, Face-priority AF, Subject-tracking AF
Face Detection
Face-priority AF function
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW + JPEG, NEF (RAW)
1920 x 1080
AV Interfaces
HDMI
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 12800, ISO 25600, ISO 100-6400
Exposure Metering
Centre-weighted, 3D colour matrix II, colour matrix II, spot (2.5%)
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, i-TTL program flash
Shooting Programs
Autumn colour, landscape, portrait mode, close-up, party/indoor, beach/snow, night portrait, PET, Children, food, night landscape, dawn/dusk, sports mode, sunset, candle, blossom
Special Effects
Neutral, Vivid, monochrome, landscape, portrait, miniature, HDR, Silhouette, Colour sketch, Colour outline, Perspective Control, Selective Colour, High Key, Night Vision, Low Key, Image Overlay, Quick retouch
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Flash, shade, 2500K - 10000K
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
5 steps in 1/3, 1/2, 2/3, 1, 2 or 3 EV steps
White Balance Bracketing
X-sync Speed
1/250sec
Exposure Range
EV 0-20 ( ISO 100 )
Lens System
Focus Adjustment
Automatic, manual
Min Focus Distance
45 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
11 groups / 15 elements
Filter Size
67 mm
Lens System Mounting
Nikon F
ED glass, Silent Wave Motor (SWM), aspherical lens, VR (Vibration Reduction)
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
12
Flash Modes
Fill-in mode, FP flash (high-speed synchro), rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
Continuous Shooting Speed
6 frames per second, 7 frames per second
Self Timer Delay
10 sec, 2sec, 5 sec, 20sec
Flash Terminal
Hot shoe
Additional Features
Direct print, USB 2.0 compatibility, date/time stamp, DPOF support, display brightness control, depth-of-field preview button, digital image rotation, camera orientation detection, PictBridge support, histogram display, AE lock, AF lock, cropping an image, resizing an image, GPS ready, Wi-Fi ready, in-camera red-eye fix, interval shooting mode, highlight point display, in-camera film editing, Active D-Lighting technology, 1080p Full HD movie recording, Dust Delete Data system, Scene Recognition System (SRS), Exif Print support, automatic display brightness adjustment, Chromatic Aberration Compensation (CAC), digital level meter, Eye-Fi Card Ready, High ISO NR, no anti-aliasing filter, long exposure noise reduction, Lens Distortion Correction
Viewfinder
Viewfinder Type
Field Coverage
100%
Magnification
0.94x
Dioptric Correction Range
-2 to +1
Viewfinder Frames
Autofocus frame
Display
3.2" LCD display
Resolution
1,228,800 pixels
Display Features
Built-in
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Sensitivity control
Connector Type
1 x Hi-Speed USB , 1 x HDMI output , 1 x remote control , 1 x microphone ( mini-phone stereo 3.5 mm ) , 1 x headphones ( mini-phone stereo 3.5 mm )
Memory Card Slot
Dual SD card
Software
Software
Drivers & Utilities, Nikon ViewNX 2
System Requirements for PC Connection
Operating System Support
MS Windows 7, Apple Mac OS X 10.4.11, MS Windows XP SP3, Apple Mac OS X 10.5.8, MS Windows Vista SP2, Apple Mac OS X 10.6.4
Peripheral Devices
USB port, CD-ROM Drive
Eyepiece cover, lens hood, battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, shoe cap
Body Material
Magnesium alloy
Protection
Splashproof, dust resistant
Battery Type
Nikon EN-EL15
Details
Battery Life Details
Photo shooting - 950 shots
Memory / Storage
Memory Card Slot
Dual SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
6000 x 4000 - DX format , 6000 x 3368 - DX-format in movie live view mode (16:9) , 4800 x 3200 - 1.3x crop , 4800 x 2696 - 1.3x crop in movie live view mode (16:9) , 4494 x 3000 - DX format , 4496 x 2528 - DX-format in movie live view mode (16:9) , 3600 x 2400 - 1.3x crop , 3600 x 2024 - 1.3x crop in movie live view mode (16:9) , 2992 x 2000 - DX format , 2992 x 1680 - DX-format in movie live view mode (16:9) , 2400 x 1600 - 1.3x crop , 2400 x 1344 - 1.3x crop in movie live view mode (16:9)
Video Capture
H.264 - 1920 x 1080 - 60 fps , H.264 - 1920 x 1080 - 50 fps , H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps
13.55 cm
7.6 cm
10.65 cm
675 g
