Nikon Coolpix S6150 - Digital camera - compact - 16.0 Mpix - 7x Optical Zoom - Violet
Quicklinx: 7Q6ZWS00 Mfr#: VNA133E1
  • SDHC Memory Card
The COOLPIX S6150 - stylish excellence at a touch.
Combining touch screen operation with cutting edge technology, the stylish COOLPIX S6150 offers intuitive operation and superb results. The NIKKOR wide-angle 7x zoom lens and 16 megapixel image sensor combine to deliver incredibly detailed photos that make great enlargements.
Sharp shots are assured thanks to four different anti-blur functions that automatically minimize the effects of camera shake, subject movement or low light. Shooting and playback are easily controlled via the high resolution touch screen, and a dedicated video-record button makes it easy to begin filming the action in high-definition.
Slim elegance meets the user-friendly high performance of 16.0 effective megapixels of imaging power, a 7x zoom Nikkor ED glass lens with 28 mm wide-angle coverage and the advantages of Nikon's advanced VR image stabilization.
The Coolpix S6150 features a LCD monitor that displays richer, more natural colors and features a wider viewing angle.
16 megapixel CCD image sensor
Lets you capture outstandingly detailed images, crop creatively and produce stunningly-sharp poster-size enlargements.
Offers outstanding precision and sharp resolution (35mm equivalent: 28-196mm).
Large 7.5 cm (3 in.), 460k-dot touch control LCD screen
For intuitive, smooth operation. Enables fingertip control over most shooting and playback functions: simply touch your subject on the screen to set the correct focus and exposure, or touch the screen with your fingertips to scroll through images.
4x anti-blur
Automatically counters blurred images in four different ways. Lens-shift Vibration Reduction) reduces the effect of camera shake. High ISO (up to 3200) light sensitivity reduces the risk of blurred images with fast-moving subjects or in low-light. Motion detection compensates for camera and subject movement. Best Shot Selector (BSS) automatically selects the sharpest of up to 10 sequential shots.
HD (720p) movie recording with stereo sound
A dedicated movie-record button makes it easy to begin recording the action. Camera features a built-in HDMI connector for output to a HDTV.
EXPEED C2 image processing system
Provides enhanced movie recording, high-sensitivity performance and maximum image quality.
Retouch Menu
Enables you to edit and enhance images in the camera. Offers a range of filter effects including Selective Color, which converts your image to monochrome then adds a splash of color to an area of your choice, and Cross Screen, which adds a starry effect to bright objects.
Smart portrait system
Advanced automatic features for perfect portraits. Smile Timer takes the shot when your chosen subject smiles. Blink Proof alerts you when someone had their eyes closed. Skin softening adjusts uneven skin tones on people's faces for smoother looking skin. In-camera Red-eye Fix corrects false eye color due to flash the instant you take the shot.
Scene Auto Selector
Selects the optimum Scene mode for popular photographic situations.
19 scene modes
Automatically optimize settings for popular photographic styles, effects and locations.
Subject Tracking AF
Will keep the camera focused on a selected subject, even if it is moving around.
  • Sophisticated performance given stylishly slim form
  • Intuitive and fun touch screen operation
    A 3-inch touch control LCD provides an intuitive and enjoyable method for shooting, viewing and retouching images. Enjoy fingertip control over most functions, including menu navigation.
  • A LCD that is a treat for the eyes
  • Slideshow magic
    Use touch operation with the built-in animated character effects and music to create original slideshows.
Nikon Coolpix S6150 - digital camera
Memory Card Slot
SD card
Image Processor
EXPEED C2
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
7 x zoom lens - 5 - 35 mm - f/3.7-5.6
Focus Adjustment
Automatic
Min Focus Distance
50 cm
Digital Zoom
4 x
Image Stabiliser
Optical
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1050 mAh ( included )
AV Interfaces
Composite video/audio, HDMI
Microsoft Certification
Compatible with Windows 7
Violet
9.8 cm x 2.7 cm x 5.8 cm
172 g
Enclosure Colour
Violet
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
16,440,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
Optical Zoom
7 x
Digital Zoom
4 x
Image Processor
EXPEED C2
Image Stabiliser
Optical
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
9
AE/AF Control
Face-priority AF, Subject-tracking AF
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1280 x 720
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto (80-1600)
Exposure Metering
Centre-weighted, matrix
Exposure Metering Zones
256
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, close-up, museum, party/indoor, backlight, night portrait, food, fireworks, night landscape, dawn/dusk, panorama assist, sports mode, sunset, beach, snow, black and white copy, pet portrait
Special Effects
Soft, fisheye, miniature, cross filter, Selective Colour
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, Flash, daylight
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
28 - 196mm
Focus Adjustment
Automatic
Min Focus Distance
50 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
7 groups / 9 elements
Built-in lens shield, ED glass
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Additional Features
Continuous Shooting Speed
1.2 frames per second
Self Timer Delay
10 sec, 2sec
Additional Features
Audio recording, direct print, USB 2.0 compatibility, touch-screen control, RGB primary colour filter, DPOF support, display brightness control, PictBridge support, Smile Detection Auto Shutter, face retouch, 720p HD movie recording, in-camera red-eye fix, face-priority AF function, Best Shot Selector (BSS), USB charging, Exif Print support, Blink Detection technology, Motion Detection Technology, Smile Detection technology, Scene Auto Selector, Smart Portrait System
Display
3" LCD display
Resolution
460,000 pixels
Display Features
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
1 x Hi-Speed USB , 1 x HDMI output , 1 x composite video/audio output
Memory Card Slot
SD card
Software
Software
Drivers & Utilities, Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Carrying strap, stylus, power adapter, USB cable, audio / video cable
Battery Type
Nikon EN-EL12
Details
Memory / Storage
RAM Installed
20 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 2592 , JPEG 4000 x 3000 , JPEG 3264 x 2448 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 1024 x 768 , JPEG 640 x 480
Video Capture
H.264 - 1280 x 720 - 30 fps , H.264 - 320 x 240 - 30 fps , H.264 - 640 x 480 - 30 fps
9.8 cm
2.7 cm
5.8 cm
172 g
