NewStar Projector Ceiling Mount 72-112 cm Tilt/Rotate
Quicklinx: 9K5LWS00 Mfr#: BEAMER-C350BLACK
The NewStar BEAMER-C350BLACK is a universal beamer/projector ceiling mount. By using this mount you can easily tilt, rotate and swivel the beamer/projector. The product can be used with every beamer. The cage-construction makes it possible to also attach beamers without a hole pattern. The distance from the ceiling to the beamer is 72 - 112 cm. This model fits virtually every projector weighing up to 12 kg. This product is a complete ceiling solution that includes all possible installation material.
  • Versatile positioning
    With height, rotation, swivel, and tilt adjustments, the Neomounts BEAMER-C350 bracket offers flexibility for projector positioning, ensuring optimal viewing angles in any room setup.
  • Seamless integration
    The BEAMER-C350 features integrated cable management, keeping cables neatly organized and out of sight for a clean and professional installation.
  • Robust design
    Designed for full-motion, this ceiling-mountable bracket supports projectors up to 12 kg, combining functionality with durability to securely hold your device in place.
Neomounts BEAMER-C350 bracket - full-motion - for projector - black
Bracket (full-motion) - ceiling mountable
Adjustable Height
72-112 cm
Tilt
90°
Swivel
360°
Adjustments
Height, tilt, swivel, rotation
Recommended Use
Projector
Max Load Weight
12 kg
5-year warranty
Adjustable Height
72-112 cm
AV Furniture
Bracket
Design
Full-motion
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Tilt
90°
Swivel
360°
Adjustments
Max Load Weight
12 kg
Adjustable height, rotating, swivel adjustment
Limited warranty - 5 years
Brand: NewStar
