The NewStar PLASMA-M2000E is a mobile floor stand for LCD/Plasma flatscreens up to 70" (175 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 115-185 cm. Cables can be placed in the column. Suited for flatscreens between 32-70" with a maximum weight of 125 kg and a maximum VESA hole pattern of 870x620 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
Versatile adjustments
With both height and tilt adjustments, the Neomounts PLASMA-M2000E offers flexibility, allowing users to find the perfect viewing angle whether for presentations, information sharing, or entertainment purposes. The height can be adjusted from 115 to 185 cm, and it also features a 15° tilt capability, ensuring optimal viewing comfort. -
Seamless cable management
The integrated cable management system keeps cables neatly organized and out of sight, contributing to a cleaner and more professional setup. This feature not only enhances the aesthetic appeal of the space but also reduces trip hazards associated with loose cables. -
Robust support for large displays
Designed to accommodate flat panels and AV systems ranging from 37" to 85" or 93.9 to 216 cm in size, the PLASMA-M2000E can support a maximum load weight of 125 kg. Its VESA mount is adjustable, fitting interfaces from 200 x 200 mm up to 870 x 620 mm, making it a versatile solution for a wide range of display needs.
- Neomounts PLASMA-M2000E cart - for flat panel / AV system - black
- Product Type
- Cart
- Adjustable Height
- 115-185 cm
- Tilt
- 15°
- Adjustments
- Height, tilt
- Recommended Use
- Flat panel / AV system
- Recommended Display Size
- 37"-85"
- VESA Mounting Interface
- From 200 x 200 mm, up to 870 x 620 mm
- Max Load Weight
- 125 kg
- Black
- Wheels Qty
- 4
- 5-year warranty
- Adjustable Height
- 115-185 cm
- Black
AV Furniture
- Cart
- Recommended Use
- Shelf Qty
- 1
- Cable Management
- Integrated cable management
- 37"-85"
- Tilt
- 15°
- Adjustments
- Height, tilt
- Max Load Weight
- 125 kg
- Wheels Qty
- 4
- VESA mount adjustable height (115 - 185 cm)
- Limited warranty - 5 years
