The NewStar PLASMA-M1800E is a mobile floor stand for LCD/Plasma flatscreens up to 60" (150 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 110-180 cm. Cables can be placed in the column. Suited for flatscreens between 27-60" with a maximum weight of 50 kg and a maximum VESA hole pattern of 600x450 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
Versatile adjustments
With both height and tilt adjustments, the Neomounts PLASMA-M1800E offers optimal viewing angles for any setting, ensuring comfort and improved visibility for your AV system or flat panel display. -
Seamless mobility
Equipped with four sturdy wheels, this cart allows for effortless movement across different rooms or locations, making it an ideal solution for dynamic environments and presentations. -
Efficient cable management
The integrated cable management system keeps cables neatly organized and out of sight, promoting a cleaner and more professional setup. -
Robust support
Designed to hold flat panels ranging from 27" to 70" and up to 50 kg in weight, the PLASMA-M1800E provides a reliable and stable platform for your display needs.
 - Neomounts PLASMA-M1800E cart - for flat panel / AV system - silver
- Product Type
 - Cart
- Adjustable Height
 - 110-180 cm
- Tilt
 - 15°
- Adjustments
 - Height, tilt
- Recommended Use
 - Flat panel / AV system
- Recommended Display Size
 - 27"-70"
- VESA Mounting Interface
 - From 200 x 200 mm, up to 600 x 450 mm
- Max Load Weight
 - 50 kg
 - Silver
- Wheels Qty
 - 4
 - 5-year warranty
- Adjustable Height
 - 110-180 cm
 - Silver
AV Furniture
 - Cart
- Recommended Use
- Shelf Qty
 - 1
- Cable Management
 - Integrated cable management
 - 27"-70"
- Tilt
 - 15°
- Adjustments
 - Height, tilt
- Max Load Weight
 - 50 kg
- Wheels Qty
 - 4
 - Adjustable height, wheels
 - Limited warranty - 5 years
