NewStar Generic Newstar Flatscreen Desk Mount 10-26" Clamp 1 Screen
Quicklinx: 9YBBWS00 Mfr#: FPMA-D960
£72.34 ex VAT
£86.80 inc VAT
The NewStar desk mount FPMA-D960 allows you to attach a LCD/TFT screen up to 26" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. It has 3 pivots. The height adjustment of 45 cm can be changed manually. The desk mount can hold screens up to 12 kg and is attached on a desk by a clamp. The arm length is 43 cm. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
  • Versatile positioning
    With adjustable depth and height, the Neomounts FPMA-D960 mounting kit offers versatile positioning options for your LCD display, ensuring optimal viewing angles and comfort.
  • Seamless rotation
    The rotating feature of the Neomounts FPMA-D960 allows for easy transition between landscape and portrait orientations, providing flexibility for various content viewing preferences.
Neomounts FPMA-D960 mounting kit - full-motion - for LCD display - black
Mounting kit (full-motion) - clamp mountable, desk-mountable
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
Tilt
180°
Rotation
360°
Swivel
180°
Adjustments
Height, tilt, swivel, rotation, depth
Recommended Use
LCD display
Recommended Display Size
10"-30"
VESA Mounting Interface
Up to 100 x 100 mm, from 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
AV Furniture
Mounting kit
Design
Full-motion
Recommended Use
LCD display
Placing / Mounting
Clamp mountable, desk-mountable
Cable Management
Integrated cable management
10"-30"
Tilt
180°
Rotation
360°
Swivel
180°
Adjustments
Max Load Weight
10 kg
Adjustable height, adjustable depth, rotating, swivel adjustment
Limited warranty - 5 years
Brand: NewStar
