NewStar Flatscreen Monitor Desk Mount
Quicklinx: C40KWS00 Mfr#: FPMA-D960DG
The NewStar desk mount, model FPMA-D960DG is a tilt-, swivel and rotatable desk mount for 2 flat screens up to 26". This mount is a great choice for space saving placement on desks using a grommet mount.
NewStars' unique tilt (180°), rotate (360°) and swivel (180°) technology allows the mount to change to any viewing angle to fully benefit from the capabilities of the flat screen. The mount is manually height adjustable from 0 to 45 centimeters. A unique cable management conceals and routes cables from mount to flat screen. Hide your cables to keep the workplace nice and tidy. NewStar FPMA-D960DG has three pivot points and is suitable for screens up to 26" (65 cm).
Neomounts FPMA-D960DG mounting kit - full-motion - for 2 LCD displays - black
Mounting kit (full-motion) - grommet, desk-mountable
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
Tilt
180°
Rotation
360°
Swivel
180°
Adjustments
Height, tilt, swivel, rotation, depth
Recommended Use
2 LCD displays
Recommended Display Size
10"-27"
VESA Mounting Interface
Up to 100 x 100 mm, from 75 x 75 mm
Max Load Weight
16 kg
5-year warranty
Adjustable Depth
10-43 cm
Adjustable Height
0-45 cm
AV Furniture
Mounting kit
Design
Full-motion
Recommended Use
2 LCD displays
Placing / Mounting
Grommet, desk-mountable
Cable Management
Integrated cable management
10"-27"
Tilt
180°
Rotation
360°
Swivel
180°
Adjustments
Max Load Weight
16 kg
Rotating, swivel adjustment
Limited warranty - 5 years
