The NewStar desk mount FPMA-D400 allows you to attach a LCD/TFT screen up to 24" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. The height adjustment is 40 cm. The desk mount can hold screens up to 10 kg and is attached on a desk by a desk clamp. The arm length is 34 cm. Cables can be placed in the column. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
Versatile adjustments
With depth, height, rotation, swivel, and tilt adjustments, the Neomounts FPMA-D400 offers flexibility. This full-motion mounting kit ensures the perfect viewing angle for any LCD display sized 10"-30", enhancing user comfort and screen visibility. -
Seamless cable management
The integrated cable management system keeps cables neatly organized and out of sight, promoting a cleaner, more professional workspace. This feature not only enhances the aesthetic appeal of your setup but also reduces clutter and potential distractions. -
Robust compatibility
Designed to support LCD displays ranging from 10" to 30" and accommodating flat panel mount interfaces from 75 x 75 mm up to 100 x 100 mm, the FPMA-D400 is a versatile solution for a wide range of setups. Its ability to handle up to 10 kg ensures reliability for a variety of display types.
- Neomounts FPMA-D400 mounting kit - full-motion - for LCD display - grey
- Product Type
- Mounting kit (full-motion) - clamp mountable, desk-mountable
- Adjustable Depth
- 10-34 cm
- Adjustable Height
- 0-40 cm
- Tilt
- 180°
- Rotation
- 270°
- Swivel
- 270°
- Adjustments
- Height, tilt, swivel, rotation, depth
- Recommended Use
- LCD display
- Recommended Display Size
- 10"-30"
- VESA Mounting Interface
- Up to 100 x 100 mm, from 75 x 75 mm
- Max Load Weight
- 10 kg
- Grey
- 5-year warranty
- Adjustable Depth
- 10-34 cm
- Adjustable Height
- 0-40 cm
- Grey
AV Furniture
- Mounting kit
- Design
- Full-motion
- Recommended Use
- LCD display
- Placing / Mounting
- Clamp mountable, desk-mountable
- Cable Management
- Integrated cable management
- 10"-30"
- Tilt
- 180°
- Rotation
- 270°
- Swivel
- 270°
- Adjustments
- Max Load Weight
- 10 kg
- Adjustable height, rotating
- Limited warranty - 5 years
