The USB 2.0 Ethernet adapter allows your computer to instantly connect to a 10 / 100 Mbps network through a USB port. This is an easy way to add network connectivity without the hassle of opening your computer case and installing an internal card. It’s also an ideal USB-to-LAN alternative for games consoles that need network access in an environment lacking wireless capability. Compared with the USB 1.1 standard which offers 12 Mbps speed, the adapters compliance with USB 2.0 (480 Mbps) ensures true 10 / 100 Mbps network speed. Furthermore, the adapter is compact and powered solely by the USB port so no external power supply is needed.
- NEWlink NLUSB2-ETHRJ - network adapter - USB 2.0 - 10/100 Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 10/100 Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0
- System Requirements
- Apple MacOS X 10.0 or later, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 / 8.1
- Network adapter
- Form Factor
- External
- USB 2.0
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- WOL, half duplex mode, full duplex mode, USB powered
- 1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated)
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- 233 MHz - RAM 64 MB
