NetPro 10dBi Omni-Directional Outdoor Antenna
Quicklinx: 6JRLWS00 Mfr#: NPOA10OD
NPOA10ODWhether your extending the wireless network from one corporate building to another, or simply from the front house to the back garden, an outdoor antenna provides a high powered solution to extend any wireless network. The Netpro 10dBi Omni-Directional Outdoor Antenna is a heavy-duty, weather proof, high powered antenna for extending the range of your 802.11b, g and N WiFi zones.
The Netpro 10dBi Omni-Directional Outdoor Antenna boosts the antenna power of standard antennas from 2dBi to 10dBi and this gives excellent performance and can potentially extended Wi-Fi distances to over 1 mile.
Installation of the Netpro 10dBi Omni-Directional Outdoor Antenna is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas. The Antenna comes equipped with N-Type, RP-SMA, RP-TNC connectors to support a wide range of wireless devices.
For optimum performance we recommend pairing the outdoor antenna with a Netpro Range Extender. Please note that you may also require an additional cable to connect your antenna to your Range Extender or other Wi-fi device.
