The XS712T is a powerful Smart Managed Switch that includes 12 ports of 10-Gigabit connectivity (12 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS712T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS712T is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
- NETGEAR XS712T 12-Port 10GBase-T Gigabit Smart Managed Switch - switch - 12 ports - smart - rack-mountable
- Switch - 12 ports - L2+ - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 10GBase-T + 2 x shared 10 Gigabit SFP+
- Performance
- Switching fabric bandwidth: 240 Gbps
- Capacity
- ACL: 100 , Virtual interfaces (VLANs): 256 , IGMP groups: 1000 , IPv4 routes: 32
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS
- Flow control, full duplex capability, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, reset button, Port Security, DHCP client, Energy Efficient Ethernet, dual firmware images, 2MB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support, 2 fans
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V
- 44 cm x 25.7 cm x 4.3 cm
- 4.04 kg
- Localisation
- Latin America, North America, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 32K entries
- 9KB
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 600 MHz
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, power, link/activity, fan
- 12 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 98.2 Watt
- Rack Mounting Kit
- Included
- MTBF
- 211,197 hours
- cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A
- Localisation
- Software Included
- Drivers & Utilities
- 44 cm
- 25.7 cm
- 4.3 cm
- 4.04 kg
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.85 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.18 |
