NetGear WNDA3100-200PES N600 Wireless Dual Band USB Adapter
Quicklinx: B82TWS00 Mfr#: WNDA3100-200PES
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
17 in stock
£19.51 ex VAT
£23.41 inc VAT
Plug & Play. Surf & Stream.
NETGEAR Wireless Adapters for high performance are the ideal for fastest downloads and high performance Internet gaming. The High Performance adapters are designed to avoid interference and come with Push `N' Connect push button security.
The NETGEAR N600 Wireless Dual Band USB Adapter wirelessly connects your Windows®-based laptop or desktop computer to a Wireless-N network for demanding applications, such as streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range, and compatibility with Wireless-G networks allows hassle-free connection flexiblity. Easy setup with NETGEAR® genie gets you up and running fast, while Push 'N' Connect gives you a secured connection at the push of a button.
Dual band avoids interference for reliable connections
Faster WiFi speeds 300/300 - Up to 600 Mbps
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
NETGEAR RangeMax WNDA3100 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3 cm x 9.5 cm x 1.5 cm
22 g
Europe
802.11a, 802.11b/g/n
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
Network adapter
External
USB 2.0
Europe
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x USB 2.0 - 4 pin USB Type A
USB cradle
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Software Included
Drivers & Utilities, NETGEAR Smart Wizard
System Requirements Details
Windows XP/Vista - Pentium - 300 MHz
3 cm
9.5 cm
1.5 cm
22 g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
