Plug & Play. Surf & Stream.
NETGEAR Wireless Adapters for high performance are the ideal for fastest downloads and high performance Internet gaming. The High Performance adapters are designed to avoid interference and come with Push `N' Connect push button security.
The NETGEAR N600 Wireless Dual Band USB Adapter wirelessly connects your Windows®-based laptop or desktop computer to a Wireless-N network for demanding applications, such as streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range, and compatibility with Wireless-G networks allows hassle-free connection flexiblity. Easy setup with NETGEAR® genie gets you up and running fast, while Push 'N' Connect gives you a secured connection at the push of a button.
Dual band avoids interference for reliable connections
Faster WiFi speeds 300/300 - Up to 600 Mbps
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
- NETGEAR RangeMax WNDA3100 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3 cm x 9.5 cm x 1.5 cm
- 22 g
- Localisation
- Europe
- Data Link Protocol
- 802.11a, 802.11b/g/n
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
- System Requirements
- Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / XP
- Microsoft Certification
- Compatible with Windows 7
- Specific Absorption Rate (SAR)
- 1.64 W/kg
- Network adapter
- Form Factor
- External
- USB 2.0
- Localisation
- Europe
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- WPS, Push ‘N’ Connect button
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- USB cradle
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- 1.64 W/kg
- Software Included
- Drivers & Utilities, NETGEAR Smart Wizard
- OS Required
- System Requirements Details
- Windows XP/Vista - Pentium - 300 MHz
- 3 cm
- 9.5 cm
- 1.5 cm
- 22 g
