The NETGEAR N300 Wireless USB Mini Adapter allows you to upgrade older laptop's Wi-Fi and connect to Wi-Fi hotspots. Mini-design makes it perfect for mobility. Push 'N' Connect gives you a secured connection at the push of a button.
Wireless-N for hotspots
Provides Wireless-N speed at hotspots for simultaneous downloads, streaming voice and music and online gaming. -
Secured connection
Push 'N' Connect offers a secured wireless Internet connection at the push of a button.
- NETGEAR WNA3100M - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3.4 cm x 1.6 cm x 0.8 cm
- 4 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista / XP / 7
- Microsoft Certification
- Compatible with Windows 7
- Specific Absorption Rate (SAR)
- 0.31 W/kg
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Push ‘N’ Connect button
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- 0.31 W/kg
- Software Included
- NETGEAR Genie
- OS Required
- 3.4 cm
- 1.6 cm
- 0.8 cm
- 4 g
