Tiny Device. Big Results.
You have a wired laptop, but you want wireless connectivity. This tiny Wireless USB Micro Adapter gives you that ability. It's a compact way to take a Windows®-based laptop on the road and connect to WiFi hotspots or move around the house while emailing and surfing online.
The NETGEAR G54/N150 Wireless USB Micro Adapter is perfect to connect your Windows®-based laptop to WiFi hotspots while on the go. The innovative micro-design is compatible with the latest in wireless connectivity and the tiny size makes it hardly noticeable when plugged into a laptop's USB port. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button.
Perfect for mobility -- Ultra small Wireless-N USB adapter fits neatly into laptop's USB port
Surf, email, chat -- Wireless-N connection for basic Internet applications
Connect to a Wireless-G or Wireless-N network
Easy setup with NETGEAR genie
Push `N' Connect offers a secured wireless Internet connection at the push of a button
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
- NETGEAR WNA1000M - network adapter - USB
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 2 cm x 1.5 cm x 0.7 cm
- 2 g
- Localisation
- Europe
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB
- Localisation
- Europe
- Connectivity Technology
- Wireless
- 150 Mbps
- Frequency Band
- 2.4 GHz
- Push ‘N’ Connect button
- Connections
- 1 x USB - 4 pin USB Type A
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium
- 2 cm
- 1.5 cm
- 0.7 cm
- 2 g
- Limited warranty - 2 years
