NetGear Wireless-N Router and USB Adapter Kit
Quicklinx: 72GWWS00 Mfr#: WNB2100-100UKS
  • IEEE 802.11n (draft 2.0)
The NETGEAR N300 wireless router and USB adapter kit is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. It provides a complete solution with wireless router and USB adapter, and free parental controls to ensure a safe Internet experience.
  • Enhanced security
    With a suite of features including 128-bit WEP, 64-bit WEP, WPA-PSK, and WPA2-PSK encryption algorithms, the NETGEAR WNB2100 ensures your network remains secure against unauthorized access and threats.
  • Seamless connectivity
    Offering both wired and wireless connectivity options, this device supports Ethernet, Fast Ethernet, and IEEE 802.11b/g/n protocols, ensuring a reliable and fast connection for all your devices.
  • Comprehensive control
    Equipped with Quality of Service (QoS), Stateful Packet Inspection (SPI), and Wi-Fi Protected Setup (WPS), the NETGEAR WNB2100 provides you with the tools to manage your network efficiently, prioritize traffic, and simplify setup.
  • Versatile compatibility
    Designed to work seamlessly with Mac, PC, and Unix systems, the NETGEAR WNB2100 offers broad compatibility, making it a versatile choice for a wide range of network environments.
NETGEAR WNB2100 - wireless router - Wi-Fi - desktop - with NETGEAR WN111 RangeMax Next Wireless-N USB Adapter
Wireless router - 4-port switch (integrated) - with NETGEAR WN111 RangeMax Next Wireless-N USB Adapter
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Remote Management Protocol
HTTP
Firewall protection, NAT support, SPI, DoS attack prevention, IDS, URL filtering, firmware upgradable, WMM support, QoS, WPS
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
17.8 cm x 13 cm x 3.5 cm
399 g
UNIX, Apple MacOS, Linux, Microsoft Windows Vista / 2000 / XP
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Status Indicators
Port status, power
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x RJ-45
Aerial
Aerial
Internal
External power adapter
Vertical stand
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
17.8 cm
13 cm
3.5 cm
399 g
