NETGEAR Wireless N 300 ADSL2+ Router Mobile Broadband Edition
Quicklinx: 79SJWS00 Mfr#: DGN2200M-100UKS
  • IEEE 802.11n
The Wireless-N 300 Router with DSL Modem Mobile Broadband Edition is a full featured wireless-n router with integrated ADSL2+ modem and a failover or backup option to connect to a 3G/4G/WiMAX mobile broadband network in case of DSL outage. Internet traffic will be temporarily routed via the secondary mobile broadband Internet access. When normal service is restored to your primary ADSL line, all traffic is switched back. The mobile broadband connection can also be used as a primary Internet connection in situations where no DSL/cable/satellite connection exists. When not using the backup option, the router can be used to share a USB storage device with any computer in the network. The solution is ideal for small and medium businesses that need the reliability of an always-on Internet connection.
The Wireless-N 300 Router with DSL Modem Mobile Broadband Edition is ideal for both professional and personal Internet use, providing Wireless-N speed and mobile hotspots for simultaneous downloads, voice and music, and online gaming. Complete with a built-in DSL modem and automatic WAN backup, it keeps you online during DSL outages.
  • Built-in DSL modem
    ADSL2+ modem and router combined create complete gateway for DSL Internet connection.
  • Stay connected
    DSL with 3G+ backup, create Wi-Fi hotspot, automatic WAN backup keeps you online during DSL outages.
  • Faster downloads and online gaming
    Provides Wireless-N speed for simultaneous downloads, streaming voice and music and online gaming, in addition to basic Internet applications.
  • Guest network access
    Provides separate security and access restrictions for guests using the network.
  • Broadband usage meter
    Monitors Internet traffic and sends customized reports to help keep costs under control.
  • Secured connection
    Push 'n' connect offer a secured wireless Internet connection at the push of a button.
NETGEAR DGN2200M - Mobile Broadband Edition - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Remote Management Protocol
HTTP
Firewall protection, DoS attack prevention, IDS, IPS, parental control, firmware upgradable, QoS, WPS, ReadySHARE
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
Environmental Standards
ENERGY STAR Qualified
17.3 cm x 12.8 cm x 3.3 cm
300 g
Apple MacOS, Microsoft Windows 2000/XP/Vista/7
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, RoHS, WEEE
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
ENERGY STAR Certified
Vertical stand, POTS filter
1 x network cable , 1 x phone cable , 1 x USB extension cable
United Kingdom
Software Included
Drivers & Utilities
17.3 cm
12.8 cm
3.3 cm
300 g
