NETGEAR Wireless-N 150 Access Point
Quicklinx: 72GTWS00 Mfr#: WN604-100UKS
  • IEEE 802.11n
The Netgear WN604 Wireless Access Point's fast wireless speeds allow you to surf, email, stream music, play on-line games, make Internet phone calls, and more. With a built-in 4 port 10/100 switch for adding extra devices such as PC, printer, or web camera, the Netgear WN604 delivers exceptional connectivity, range and speed
Key Features
- Advanced Wireless-N technology delivers exceptional range and speed
- Up to 15x the speed and 5x the coverage of Wireless-G technology†
- Compared to Wireless-G, Wireless-N 150 provides better wireless coverage with Wireless-G devices and better speed with Wireless-N devices
- Push `N' Connect using Wi-Fi Protected Setup (WPS)1 - A secured connection at the push of a button
Netgear Green Technology
- Convenient power and Wi-Fi on/off switches to conserve energy
- Packaging manufactured with at least 80% recycled materials
Security
- Wi-Fi Protected Access (WPA-PSK,WPA2-PSK)
- Wireless Equivalent Privacy (WEP)
-64-bit, 128-bit, 152-bit encryption for IEEE 802.11b and IEEE 802.11g
-Wireless access control to identify authorized wireless network device
-MAC address authentication
-802.1x RADIUS support with EAP TLS, TTLS, PEAP
-Wi-Fi Protected Setup (WPS) push button and PIN
-Push "N" Connect using Wi-Fi
-Protected Setup (WPS) and Smart Wizard
Package Contents
-Netgear WN604 Wireless-N 150 Access Point
-Ethernet cable
-Resource CD
-Installation guide
-Power adapter
2.4 GHz 802.11n 2.0 adapter or 802.11b/g wireless adapter. Or, Ethernet adapter and cable for each computer
OS Requirements
Microsoft Windows 7 Vista, XP, 2000, Mac OS, UNIX, or Linux
Browser Requirements
Microsoft Internet Explorer 7.0, Firefox 2.0 or higher
Standards
IEEE 802.11n version 2.0, IEEE802.11g, IEEE 802.11b, 2.4GHz, Wireless Distribution System (repeater and Wireless Client mode support), Wi-Fi Multimedia (WMM) to optimise audio, video and voice applications
Dimensions
175 x 118 x 28mm
0.399kg
