NetGear WiFi Booster for Mobile
SALE PRICE! - WAS £39.99
Quicklinx: 8NK0WS00 Mfr#: WN1000RP-100UKS
  • IEEE 802.11n
NETGEAR WiFi Booster for Mobile amplifies WiFi coverage for mobile devices in the home by extending and strengthening an existing WiFi signal, giving you the ability to enjoy an improved wireless experience on iPads and Android tablets, smartphones, netbooks and e-readers.
DYNAMIC LED INDICATORS
Finds best location for optimal WiFi coverage and displays real-time, end-to-end network status.
wn1000rp Dynamic LEDs
Connection status between router/gateway and Extender
On/off status of Extender
Connection status between Extender and PC
PUSH 'N' CONNECT USING WPS - A secured connection at the push of a button STEP 1
Push the 'N' Connect button on the router
STEP 2
Push 'N' Connect button on your extender
STEP 3
Secure wireless connection
Boost WiFi -- Amplify your network by boosting the WiFi signal around the house and even outside on the patio Ideal for Mobile -- Extend your WiFi network for mobile devices like iPads®, iPods®, Android® tablets, e-readers, smartphones, and netbooks Reduce mobile data charges -- Reduce 3G/4G mobile data usage by connecting to WiFi while at home Enhance Existing Equipment -- Keep your current equipment and improve coverage to eliminate WiFi "dead zones" Easy Install - Simple install for all devices using a browser, no CD needed Push 'N' Connect -- Push `N' Connect using Wi-Fi Protected Setup® (WPS) allows for a quick and secure connection Optimal Coverage -- Real-time LEDs locate the best placement spot to provide optimal WiFi coverage Universal Compatibility -- Extends b/g/n WiFi signals from any existing WiFi router or service provider gateway like Belkin®, Linksys®, D-Link®, AT&T™, 2Wire®, Verizon, EarthLink®, NETGEAR® and others‡ Superior Security -- Works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP NETGEAR Green features -- Power on/off button, 80% recycled packaging
  • Boost Wi-Fi
    Amplify your network by boosting the Wi-Fi signal around the house and even outside on the patio.
  • Ideal for mobile
    Extend your Wi-Fi network for mobile devices like iPads, iPods, Android tablets, e-Readers, smartphones, and netbooks.
  • Reduce mobile data charges
    Reduce 3G/4G mobile data usage by connecting to Wi-Fi while at home.
  • Enhance existing equipment
    Keep your current equipment and improve coverage to eliminate Wi-Fi "dead zones".
  • Easy install
    It offers simple install for all devices using a browser, no CD needed.
  • Push 'N' connect
    Push 'N' connects using Wi-Fi Protected Setup (WPS) allows for a quick and secure connection.
  • Optimal coverage
    Real-time LEDs locate the best placement spot to provide optimal Wi-Fi coverage.
  • Universal compatibility
    It extends b/g/n Wi-Fi signals from any existing Wi-Fi router or service provider gateway like Belkin, Linksys, D-Link, AT and T, 2Wire, Verizon, EarthLink, NETGEAR and others.
  • Superior security
    It can works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP.
  • NETGEAR green features
    Power on/off button, 80% recycled packaging.
NETGEAR WN1000RP WiFi Booster for Mobile - Wi-Fi range extender - Wi-Fi
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
6.7 cm x 5.5 cm x 3.4 cm
100 g
1-year warranty
6.7 cm
5.5 cm
3.4 cm
100 g
United Kingdom
External
Wireless
Frequency Band
2.4 GHz
Status Indicators
Power, status
Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
External power adapter
Limited warranty - 1 year
