The WAX620 is a high-performance Wi-Fi 6 access point, ideal for small and medium sized businesses. The access point is a dual-band 4x4 design delivering up to 3.6Gbps total Wi-Fi throughput, supported by a 2.5Gbps Power-over-Ethernet port, an industry leader of performance and cost effectiveness in its product class.
The WAX620 supports the next-generation Wi-Fi 6 smart phones, IoT devices, and notebook computers, delivering up to 40% more throughput to each individual device in the 5GHz band and 100% more throughput in the 2.4GHz band, compared to the previous generation equivalent model; provides 4x the client device connection, allowing businesses to serve more customers with better speed and less congestion.
The WAX620 is ideal in high-density client device environments such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security. With Insight management, WAX620 works seamlessly with your current NETGEAR Insight managed switches, Wi-Fi access points and network storage, and is compatible with previous generation Wi-Fi devices (Wi-Fi 5 802.11ac for example) and Wi-Fi access points.
Enhanced connectivity
With support for 802.11ax, also known as Wi-Fi 6, the NETGEAR Insight WAX620 offers faster and more efficient wireless connectivity. This technology ensures that a larger number of devices can connect simultaneously without sacrificing speed or reliability. -
Robust security
The WAX620 provides comprehensive security features including WPA3 encryption and support for Extensible Authentication Protocol (EAP), RADIUS, and more. These features ensure a secure network environment, protecting sensitive data from unauthorized access. -
High performance
Equipped with 4x4 MU-MIMO technology and capable of delivering up to 2400 Mbps on the 5 GHz band and 1200 Mbps on the 2.4 GHz band, this wireless access point is designed to support high-bandwidth activities without interruption. -
Versatile deployment
This device is designed for indoor use with a ruggedized chassis and can be mounted on a wall or ceiling, providing flexibility in deployment according to the spatial requirements of any office or business environment. -
Intelligent management features
Features such as band steering, VLAN support, and Target Wait Time (TWT) contribute to efficient network management and optimization, ensuring that users experience seamless connectivity and reduced power consumption.
- NETGEAR Insight WAX620 - radio access point - Wi-Fi 6
- Radio access point
- Form Factor
- Wall / ceiling mountable - indoor
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum throughput (5 GHz): 2400 Mbps , Maximum throughput (2.4 GHz): 1200 Mbps
- Capacity
- Maximum number of users: 256 , Concurrent users: 75 , SSIDs total: 8 , Streams: 8
- Included Accessories
- Wall/ceiling mounting kit
- Power Over Ethernet (PoE) Supported
- PoE+
- 20.57 cm x 20.57 cm x 3.43 cm
- 783 g
- 5-year warranty
- Ruggedized Design
- Indoor
- 20.57 cm
- 20.57 cm
- 3.43 cm
- 783 g
- Localisation
- Europe
- Form Factor
- Connectivity Technology
- Wireless
- Line Coding Format
- OFDMA, OFDM
- Spread Spectrum Method
- OFDMA, OFDM
- Remote Management Protocol
- RADIUS
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- Wi-Fi Rating
- AX3600
- Status Indicators
- Power, LAN, 2.4/5 GHz
- 4x4 MU-MIMO technology, VLAN support, BSS Coloring, Target Wait Time (TWT), Beamforming+, WDS bridge, WDS PTMP (Point to Multipoint), WDS PTP (Point to Point), WDS repeater mode, MAC address filtering, 802.1x authentication, Neighbor AP detection, Block SSID Broadcast, Guest Network, Captive Portal, bandwidth control, LLDP support, band steering, Backhaul Technology, Wi-Fi Multimedia (WMM) support, Wireless Distribution System (WDS) support, auto-uplink (auto MDI/MDI-X), Transmit Power Control (TPC)
- Encryption Algorithm
- WPA-Enterprise, SSL, WPA, WPA2, WPA3, TLS, TTLS, PEAP, WPA2-Enterprise
- Authentication Method
- RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, IEEE 802.3at, IEEE 802.3af, IEEE 802.11i, IEEE 802.1x, IEEE 802.1ab (LLDP)
Aerial
- Antenna
- Internal
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- 1 x 1/2.5GBase-T (PoE+) - RJ-45
- PoE+
- Software Included
- NETGEAR Insight (1 year subscription)
- Limited warranty - replacement - 5 years - response time: next business day ¦ Technical support - 90 days
- 0 °C
- 40 °C
