NETGEAR WiFi 6 WAX620 Dual-band Access Point
Quicklinx: GCZSWS00 Mfr#: WAX620-100EUS
Type: Radio access point
Connectivity: Wireless
Speed: 3.6Gbps
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11a, IEEE 802.11n + 2 more
Compatibility: [N/A]
  • IEEE 802.11n
32 In Stock
£188.56 ex VAT
£226.27 inc VAT
The WAX620 is a high-performance Wi-Fi 6 access point, ideal for small and medium sized businesses. The access point is a dual-band 4x4 design delivering up to 3.6Gbps total Wi-Fi throughput, supported by a 2.5Gbps Power-over-Ethernet port, an industry leader of performance and cost effectiveness in its product class.
The WAX620 supports the next-generation Wi-Fi 6 smart phones, IoT devices, and notebook computers, delivering up to 40% more throughput to each individual device in the 5GHz band and 100% more throughput in the 2.4GHz band, compared to the previous generation equivalent model; provides 4x the client device connection, allowing businesses to serve more customers with better speed and less congestion.
The WAX620 is ideal in high-density client device environments such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security. With Insight management, WAX620 works seamlessly with your current NETGEAR Insight managed switches, Wi-Fi access points and network storage, and is compatible with previous generation Wi-Fi devices (Wi-Fi 5 802.11ac for example) and Wi-Fi access points.
  • Enhanced connectivity
    With support for 802.11ax, also known as Wi-Fi 6, the NETGEAR Insight WAX620 offers faster and more efficient wireless connectivity. This technology ensures that a larger number of devices can connect simultaneously without sacrificing speed or reliability.
  • Robust security
    The WAX620 provides comprehensive security features including WPA3 encryption and support for Extensible Authentication Protocol (EAP), RADIUS, and more. These features ensure a secure network environment, protecting sensitive data from unauthorized access.
  • High performance
    Equipped with 4x4 MU-MIMO technology and capable of delivering up to 2400 Mbps on the 5 GHz band and 1200 Mbps on the 2.4 GHz band, this wireless access point is designed to support high-bandwidth activities without interruption.
  • Versatile deployment
    This device is designed for indoor use with a ruggedized chassis and can be mounted on a wall or ceiling, providing flexibility in deployment according to the spatial requirements of any office or business environment.
  • Intelligent management features
    Features such as band steering, VLAN support, and Target Wait Time (TWT) contribute to efficient network management and optimization, ensuring that users experience seamless connectivity and reduced power consumption.
NETGEAR Insight WAX620 - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable - indoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum throughput (5 GHz): 2400 Mbps , Maximum throughput (2.4 GHz): 1200 Mbps
Maximum number of users: 256 , Concurrent users: 75 , SSIDs total: 8 , Streams: 8
Wall/ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
20.57 cm x 20.57 cm x 3.43 cm
783 g
5-year warranty
Radio access point
Ruggedized Design
Indoor
20.57 cm
20.57 cm
3.43 cm
783 g
Europe
Wireless
Line Coding Format
OFDMA, OFDM
Spread Spectrum Method
OFDMA, OFDM
Remote Management Protocol
RADIUS
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX3600
Status Indicators
Power, LAN, 2.4/5 GHz
4x4 MU-MIMO technology, VLAN support, BSS Coloring, Target Wait Time (TWT), Beamforming+, WDS bridge, WDS PTMP (Point to Multipoint), WDS PTP (Point to Point), WDS repeater mode, MAC address filtering, 802.1x authentication, Neighbor AP detection, Block SSID Broadcast, Guest Network, Captive Portal, bandwidth control, LLDP support, band steering, Backhaul Technology, Wi-Fi Multimedia (WMM) support, Wireless Distribution System (WDS) support, auto-uplink (auto MDI/MDI-X), Transmit Power Control (TPC)
Encryption Algorithm
WPA-Enterprise, SSL, WPA, WPA2, WPA3, TLS, TTLS, PEAP, WPA2-Enterprise
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, IEEE 802.3at, IEEE 802.3af, IEEE 802.11i, IEEE 802.1x, IEEE 802.1ab (LLDP)
Aerial
Antenna
Internal
Internet of Things (IoT)
1 x 1/2.5GBase-T (PoE+) - RJ-45
PoE+
Software Included
NETGEAR Insight (1 year subscription)
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
Speed: 3.6Gbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ax (Wi-Fi 6)
Antennas: [N/A]
Brand: NETGEAR
