The WAX610 supports Wi-Fi 6 smartphones, IoT devices, and notebook computers, delivering more throughput to each individual device in the 5 GHz band. The WAX610 is ideal in high-density client device environments such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security.
Ultimate speed and capacity
Offer customers and employees Wi-Fi with higher speeds, less congestion, higher device density and higher battery life for Wi-Fi 6 devices with WAX610Y. -
Wi-Fi security for your business
Small and medium organizations enjoy enterprise-level security without the enterprise budget. Insight helps you configure and maintain the security of the network easily.
- NETGEAR Insight WAX610Y - radio access point - Wi-Fi 6 - cloud-managed
- Radio access point
- Form Factor
- External - outdoor
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of users: 250 , Concurrent users: 30
- Included Accessories
- Wall/ceiling mounting kit, pole/wall mount kit
- Power Over Ethernet (PoE) Supported
- PoE+
- 18.1 cm x 30.5 cm x 3.4 cm
- 940 g
- 5-year warranty
- Ruggedized Design
- Outdoor
- 18.1 cm
- 30.5 cm
- 3.4 cm
- 940 g
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Line Coding Format
- OFDM, OFDMA
- Remote Management Protocol
- SSH, RADIUS
- Cloud-Managed
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Wi-Fi Rating
- AX1800
- Status Indicators
- Power, LAN, 2.4/5 GHz
- VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Mesh networking, Wi-Fi Multimedia (WMM) support, LLDP support, Neighbor Discovery Protocol (NDP), Captive Portal, 802.1x authentication, Transmit Power Control (TPC), MU-MIMO technology, band steering, guest access, bridge mode, Target Wait Time (TWT), BSS Coloring
- Encryption Algorithm
- SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
- Authentication Method
- Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
- Antenna
- Internal
- 1 x 1/2.5GBase-T (PoE+) - RJ-45
- IP55
- PoE+
- Software Included
- NETGEAR Insight (1 year subscription)
- Limited warranty - replacement - 5 years - response time: next business day ¦ Technical support - 90 days
