NETGEAR WiFi 6 WAX610Y Outdoor Access Point
Quicklinx: GCZRWS00 Mfr#: WAX610Y-100EUS
Type: Radio access point
Connectivity: Wireless
Speed: [N/A]
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 2 more
Compatibility: [N/A]
  • IEEE 802.11n
£180.36 ex VAT
£216.43 inc VAT
The WAX610 supports Wi-Fi 6 smartphones, IoT devices, and notebook computers, delivering more throughput to each individual device in the 5 GHz band. The WAX610 is ideal in high-density client device environments such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security.
  • Ultimate speed and capacity
    Offer customers and employees Wi-Fi with higher speeds, less congestion, higher device density and higher battery life for Wi-Fi 6 devices with WAX610Y.
  • Wi-Fi security for your business
    Small and medium organizations enjoy enterprise-level security without the enterprise budget. Insight helps you configure and maintain the security of the network easily.
NETGEAR Insight WAX610Y - radio access point - Wi-Fi 6 - cloud-managed
Radio access point
External - outdoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz
Maximum number of users: 250 , Concurrent users: 30
Wall/ceiling mounting kit, pole/wall mount kit
Power Over Ethernet (PoE) Supported
PoE+
18.1 cm x 30.5 cm x 3.4 cm
940 g
5-year warranty
Radio access point
Ruggedized Design
Outdoor
18.1 cm
30.5 cm
3.4 cm
940 g
Europe
External
Wireless
Line Coding Format
OFDM, OFDMA
Remote Management Protocol
SSH, RADIUS
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AX1800
Status Indicators
Power, LAN, 2.4/5 GHz
VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Mesh networking, Wi-Fi Multimedia (WMM) support, LLDP support, Neighbor Discovery Protocol (NDP), Captive Portal, 802.1x authentication, Transmit Power Control (TPC), MU-MIMO technology, band steering, guest access, bridge mode, Target Wait Time (TWT), BSS Coloring
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
1 x 1/2.5GBase-T (PoE+) - RJ-45
IP55
PoE+
Software Included
NETGEAR Insight (1 year subscription)
Limited warranty - replacement - 5 years - response time: next business day ¦ Technical support - 90 days
Speed: [N/A]
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ax (Wi-Fi 6)
Antennas: [N/A]
Brand: NETGEAR
