NETGEAR WiFi 6 WAX610 Access Point
Quicklinx: GCZQWS00 Mfr#: WAX610-100EUS
Type: Radio access point
Connectivity: Wireless
Speed: 1.8Gbps
Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11b + 2 more
Compatibility: [N/A]
  • IEEE 802.11n
More than 50 In Stock
£152.71 ex VAT
£183.25 inc VAT
The WAX610 supports the next generation Wi-Fi 6 smartphones, IoT devices, and notebook computers, delivering up to 40% more throughput to each individual device in the 5GHz band and 70% more throughput in the 2.4GHz band, compared to the previous generation equivalent model; provides 4x the client device connection, allowing businesses to serve more customers with better speed and less congestion.
The WAX610 is ideal in high-density client device environments, such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security. With Insight management, WAX610 works seamlessly with your current NETGEAR Insight managed switches, Wi-Fi access points and network storage, and is compatible with previous generation Wi-Fi devices (Wi-Fi 5 802.11ac for example) and Wi-Fi access points.
In the past several years, the Wi-Fi industry has made progress in increasing speeds by leaps and bounds. However, capacity continues to be a challenge, namely, supporting a large number of concurrent users. This requirement is particularly acute for businesses, where very high throughput to each individual device may not be the paramount requirement. Rather, it is providing network connectivity to a large number of client devices, with good throughput, stable connection, and robust responses to environmental changes that is most important.
With the updated Wi-Fi 6 (802.11ax) technology such as OFDMA, upstream and downstream MU-MIMO, and increased speeds, coverage, and capacity, you can feel confident that you're getting the highest performance Wi-Fi that's set for years to come! Plus the assurance that you can now add more connected devices on your business Wi-Fi network without any slowdowns or blind spots.
The WAX610, a Wi-Fi 6 business access point, combined with Insight, helps small and medium businesses with an easy way to manage their network without an IT expert, providing great Wi-Fi connection leaving each of their customers satisfied as a network user. NETGEAR empowers businesses with a Wi-Fi 6 business access point for high performance and high coverage for the years to come.
  • Enhanced security
    With a comprehensive suite of encryption algorithms including PEAP, SSL, TLS, TTLS, WPA, WPA2, WPA2-Enterprise, and WPA3, the NETGEAR Insight WAX610 offers robust security measures to protect sensitive data and ensure a secure connection for all users.
  • Advanced connectivity
    Featuring Wi-Fi 6 (802.11ax) technology, the NETGEAR Insight WAX610 supports higher data rates, increased capacity, and improved power efficiency, making it ideal for high-density environments. Its dual-band capabilities allow for seamless connectivity across both 2.4 GHz and 5 GHz bands, ensuring optimal performance for a wide range of devices.
  • Powerful performance
    Equipped with MU-MIMO technology and Target Wait Time (TWT), the NETGEAR Insight WAX610 delivers efficient, high-speed wireless performance. Transmit Power Control (TPC) and band steering further enhance the user experience by optimizing signal strength and reducing interference.
  • Versatile deployment
    The ruggedized indoor design and support for Power over Ethernet (PoE+) enable flexible installation options for the NETGEAR Insight WAX610. Its external form factor and multiple mounting options make it easy to integrate into any setting, from offices to classrooms.
  • Comprehensive management
    With features like MAC address filtering, VLAN support, and Wi-Fi Multimedia (WMM) support, the NETGEAR Insight WAX610 offers advanced network management capabilities. LLDP support and Wireless Distribution System (WDS) support further extend its functionality, making it a versatile choice for businesses of all sizes.
NETGEAR Insight WAX610 - radio access point - Wi-Fi 6 - cloud-managed
Radio access point
External - indoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz
Maximum number of users: 250 , Concurrent users: 30
Wall/ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
16.09 cm x 16.09 cm x 3.325 cm
412 g
5-year warranty
Radio access point
Ruggedized Design
Indoor
16.09 cm
16.09 cm
3.325 cm
412 g
Europe
External
Wireless
Line Coding Format
OFDM, OFDMA
Remote Management Protocol
SSH, RADIUS
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AX1800
Status Indicators
Power, LAN, 2.4/5 GHz
VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Mesh networking, Wi-Fi Multimedia (WMM) support, LLDP support, Neighbor Discovery Protocol (NDP), Captive Portal, 802.1x authentication, Transmit Power Control (TPC), MU-MIMO technology, band steering, guest access, bridge mode, Target Wait Time (TWT), BSS Coloring
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
1 x 1/2.5GBase-T (PoE+) - RJ-45
PoE+
Software Included
NETGEAR Insight (1 year subscription)
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
Speed: 1.8Gbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11ax (Wi-Fi 6)
Antennas: [N/A]
Brand: NETGEAR
