The NETGEAR Wi-Fi 6 AX3600 PoE Wireless Access Point (AP) delivers 802.11ax high performance wireless connectivity for Small Office and Home Office (SOHO) deployments and supports dual band concurrent Wi-Fi 6 operations at 2.4GHz and 5GHz with a combined throughput of 3.6Gbps (1200Mbps at 2.4GHz and 2400Mbps at 5GHz). The WAX218 Wi-Fi 6 Access Point provides standalone configuration with easy setup for a reliable, Wi-Fi 6 802.11ax high performance, and cost-effective wireless solution. The WAX218 can be powered by Power-Over-Ethernet or a DC power adapter.
Enhanced connectivity
With support for Wi-Fi 6 (802.11ax) standard, the NETGEAR WiFi 6 AX3600 PoE+ Access Point offers more efficient Internet connectivity, ensuring smooth streaming, gaming, and downloading across all your devices. -
Robust security
Equipped with WPA3 encryption, the most advanced Wi-Fi security protocol, this access point provides protection against unauthorized access and ensures your network stays secure. -
Extensive coverage
Featuring a high-gain 5 dBi antenna and the capacity to support up to 256 clients, this access point is designed to offer extensive coverage and support for a multitude of devices, making it ideal for busy environments. -
Seamless operation
With a maximum throughput of 1147 Mbps on the 2.4 GHz band and 2402 Mbps on the 5 GHz band, coupled with Quality of Service (QoS) support, it delivers a seamless Internet experience, prioritizing traffic to ensure critical applications get the bandwidth they need. -
Durable and reliable
Designed for durability, the NETGEAR WiFi 6 AX3600 PoE+ Access Point operates within a wide temperature range (0°C to 40°C) and boasts an impressive MTBF (Mean Time Between Failures) of 1,896,453 hours, ensuring long-term reliability.
 - NETGEAR WiFi 6 AX3600 PoE+ Access Point - radio access point - Wi-Fi 6
 - Radio access point
- Form Factor
 - Wall / ceiling mountable
- Localisation
 - Europe
- Data Link Protocol
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac, 802.11ax
- Frequency Band
 - 2.4 GHz, 5 GHz
- Performance
 - Maximum throughput (2.4 GHz): 1147 Mbps , Maximum throughput (5 GHz): 2402 Mbps
- Capacity
 - Maximum number of clients: 256 , SSIDs total: 4
 - 20.573 cm x 20.573 cm x 3.475 cm
 - 788 g
 - 3-year warranty
 - 20.573 cm
 - 20.573 cm
 - 3.475 cm
 - 788 g
- Localisation
 - Europe
- Form Factor
- Connectivity Technology
 - Wireless
- Frequency Band
 - 2.4 GHz, 5 GHz
- Performance
- Capacity
- Wi-Fi Rating
 - AX3600
- Status Indicators
 - Power, LAN, 2.4/5 GHz
 - Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, SOHO (Small Office/Home Office)
- Encryption Algorithm
 - WPA, WPA2, WPA3
- Authentication Method
 - Radio Service Set ID (SSID)
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
- Antenna
 - Internal
- Gain Level
 - 5 dBi
 - 1 x 1000Base-TX (PoE+) - RJ-45
- Cables Included
 - 1 x network cable
- MTBF
 - 1,896,453 hours
 - EN 60950, CB, EN 62368
 - Limited warranty - 3 years , Technical support - 90 days
 - 0 °C
 - 40 °C
 - 5 - 95%
