NETGEAR WiFi 6 WAX218 Access Point
Quicklinx: GCZPWS00 Mfr#: WAX218-100EUS
  • IEEE 802.11n (draft 2.0)
£194.94 ex VAT
£233.92 inc VAT
The NETGEAR Wi-Fi 6 AX3600 PoE Wireless Access Point (AP) delivers 802.11ax high performance wireless connectivity for Small Office and Home Office (SOHO) deployments and supports dual band concurrent Wi-Fi 6 operations at 2.4GHz and 5GHz with a combined throughput of 3.6Gbps (1200Mbps at 2.4GHz and 2400Mbps at 5GHz). The WAX218 Wi-Fi 6 Access Point provides standalone configuration with easy setup for a reliable, Wi-Fi 6 802.11ax high performance, and cost-effective wireless solution. The WAX218 can be powered by Power-Over-Ethernet or a DC power adapter.
  • Enhanced connectivity
    With support for Wi-Fi 6 (802.11ax) standard, the NETGEAR WiFi 6 AX3600 PoE+ Access Point offers more efficient Internet connectivity, ensuring smooth streaming, gaming, and downloading across all your devices.
  • Robust security
    Equipped with WPA3 encryption, the most advanced Wi-Fi security protocol, this access point provides protection against unauthorized access and ensures your network stays secure.
  • Extensive coverage
    Featuring a high-gain 5 dBi antenna and the capacity to support up to 256 clients, this access point is designed to offer extensive coverage and support for a multitude of devices, making it ideal for busy environments.
  • Seamless operation
    With a maximum throughput of 1147 Mbps on the 2.4 GHz band and 2402 Mbps on the 5 GHz band, coupled with Quality of Service (QoS) support, it delivers a seamless Internet experience, prioritizing traffic to ensure critical applications get the bandwidth they need.
  • Durable and reliable
    Designed for durability, the NETGEAR WiFi 6 AX3600 PoE+ Access Point operates within a wide temperature range (0°C to 40°C) and boasts an impressive MTBF (Mean Time Between Failures) of 1,896,453 hours, ensuring long-term reliability.
NETGEAR WiFi 6 AX3600 PoE+ Access Point - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum throughput (2.4 GHz): 1147 Mbps , Maximum throughput (5 GHz): 2402 Mbps
Maximum number of clients: 256 , SSIDs total: 4
20.573 cm x 20.573 cm x 3.475 cm
788 g
3-year warranty
Radio access point
20.573 cm
20.573 cm
3.475 cm
788 g
Europe
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX3600
Status Indicators
Power, LAN, 2.4/5 GHz
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, SOHO (Small Office/Home Office)
Encryption Algorithm
WPA, WPA2, WPA3
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Gain Level
5 dBi
1 x 1000Base-TX (PoE+) - RJ-45
1 x network cable
MTBF
1,896,453 hours
EN 60950, CB, EN 62368
Limited warranty - 3 years , Technical support - 90 days
5 - 95%
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n (draft 2.0)
Protocol: IEEE 802.11g
Protocol: 802.11ax
Brand: NETGEAR
