NETGEAR WG311 54 Mbps Wireless PCI Adapter - network adapter
Customer rating: 3.0* (Write a review)
Quicklinx: 2NYGWS00 Mfr#: WG311GE
At 54 Mbps, this wireless 2.4 GHz 802.11b/g PCI card is much faster than existing 11 Mbps wireless networks and will supercharge the delivery of media-rich content to your desktop PC as never before. It easily handles huge digital video and MP3 files, firing them through your network at blazing speeds. It gives you continuous access to your home wireless router or office network, saves the time and expense of installing Ethernet cabling when you want to set up or expand a network, and makes it simple to relocate your desktop PC without rewiring. Moreover, it allows network users to wirelessly share a broadband Internet connection for access to corporate resources, the Internet, and e-mail all with the highest available level of industry standard WEP encryption security.
This high-speed 802.11g PCI card delivers large files in the blink of an eye up to five times faster than 802.11b, allowing wireless video streaming for the first time ever. Dynamic rate shifting according to environmental conditions achieves the fastest possible connections.
The card adds convenient mobility and reliable standards-based wireless connectivity to a network from a desktop PC via an 802.11b, 802.11g, or dual-band router or access point. It makes the most of your broadband connection, allowing network users to wirelessly share one IP address. The card quickly and easily networks employees for ongoing access to corporate resources, e-mail, and the Internet.
Secure 40/64 and 128-bit Wired Equivalency Protection (WEP) encryption allows for secure data transfer and increased shielding from wireless eavesdroppers. The card supports Virtual Private Network (VPN) pass-through for protected communication over the public Internet. It is simple to install and use.
Please note - this is not compatible with Windows 7
NETGEAR WG311 - network adapter - PCI
Network adapter
Plug-in card
Interface (Bus) Type
PCI
2.2 cm x 13.3 cm x 12.1 cm
0.1 kg
802.11b/g
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g
Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP
3-year warranty
Network adapter
Plug-in card
PCI
Wireless
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
VPN support, dynamic rate shifting
Compatible Slots
1 x PCI
Encryption Algorithm
128-bit WEP, 40-bit WEP
FCC Class B certified
Software Included
Drivers & Utilities
Min Processor Type
Pentium III
Min Hard Drive Space
20 MB
2.2 cm
13.3 cm
12.1 cm
0.1 kg
Limited warranty - 3 years
Customer reviews
Write a review for the NETGEAR WG311 54 Mbps Wireless PCI Adapter - network adapter here!
Reviewed by S Tweddle. Review Posted 04/08/2007
Always been a fan of netgear for their easy to use software - which is fine but it disabled fast user switching on the XP PC that it was installed in. No big problem you might say but the PC was for my parents who aren't experienced users so it would've been another thing to slow them down. Might have been down to something else conflicting but I could'nt find anything, removed the netgear software altogether and just installed drivers and they now use windows wireless utility with no issues.- Hardware is robust and does the job. Slightly on the expensive end of the market but then again 'You get what you pay for' good quality and the name that you trust.
  • Overall 5*
  • Ease of use 3*
  • Value for money 4*
Netgear WG311
Reviewed by AP IT Solutions. Review Posted 26/10/2005
I have always found NETGEAR kit to be robust and reliable and the WG311 is no exception. It's also very easy to fit and the instructions are clear and non-technical.
At nearly £30 it is at the expensive end of the market, but you could waste a lot of time by buying cheaper cards and spending a lot of time getting them to work.
I have found the card works well with other manufacturers equipment and Windows XP picks it up immediately when installing (remember to install the software first!)
  • Overall 4*
  • Ease of use 5*
  • Value for money 3*
It does exactly what it says on the box
Reviewed by Anonymous Review Posted 11/05/2004
Got this yesterday and installed and set up in about ten minutes. For those who like that kind of detail my PC is an IBM P3 1800 with 512RAM etc etc . Early days yet but signal strength is fine despite my router being two floors away and the other side of two brick walls and a stone chimney wall - not ideal i know but its the only place i can cover both the house and garden from.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
