The NETGEAR ProSAFE WC7600 Premium Wireless Controller is a fully featured enterprise class, high performance and secured wireless controller capable of managing up to 150 Access Points and 6,000 concurrent clients per cluster. The WC7600 delivers ultra-fast Access Point discovery, Layer 2 and Layer 3 fast roaming, multiple 10 Gigabit connectivity, a captive portal for guest access, fully distributed architecture, and ease of configuration and management.
Unlike other Wireless systems that are costly, complex and cumbersome to deploy, the WC7600 wireless controller is ideal for K-12 education, hospitality, and healthcare deployments. Designed with simplicity in mind for management and ease of use, it offers enterprise grade functionality and capability for small to mid-sized organizations, without the cost and complexity of big IT.
- NETGEAR WB7630 Business Controller Bundle - wireless network management device - with 10 x NETGEAR ProSafe Business 3 x 3 Dual Band Wireless-AC Access Point WAC730 and 1x WC10APL license for 10 Access Point management
- Wireless network management device
- Form Factor
- External - 1U
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, PPP
- Capacity
- Manageable access points: 10 , Maximum number of access points: 15 , BSSIDs: 144 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
- Power
- AC 100/230 V
- 44 cm x 26.2 cm x 4.3 cm
- 3.6 kg
- Limited lifetime warranty
- Bundled with
- 10 x NETGEAR ProSafe Business 3 x 3 Dual Band Wireless-AC Access Point WAC730 and 1x WC10APL license for 10 Access Point management
- Height (Rack Units)
- 1U
- 44 cm
- 26.2 cm
- 4.3 cm
- 3.6 kg
- Bundled with
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
- Routing Protocol
- CIDR
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, Telnet, HTTP, TFTP, SSH
- Capacity
- Auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, IPv6 support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), IPv4 support, rogue access point detection, Management Information Base (MIB), rate limit
- Encryption Algorithm
- DES, Triple DES, RC4, AES, IKE, SSL, TKIP, WPA, PKI, AES-CCMP, AES-CCM, WPA2-PSK, WPA2-Enterprise, AES-CBC, TLS 1.1, WEP
- Authentication Method
- RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
- 4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
- MTBF
- 664,072 hours
- Voltage Required
- AC 100/230 V
- 13 Watt
- Limited warranty - replacement - lifetime - response time: next business day
- 0 °C
- 45 °C
- 10 - 90%
