NETGEAR WAC104-100UKS Dual Band 802.11ac Wireless Access Point
Quicklinx: CHLXWS00 Mfr#: WAC104-100UKS
  • IEEE 802.11n (draft 2.0)
The NETGEAR WAC104 Wireless Access Point is a cost-effective, high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2Gbps. To fully maximize the wireless throughput, the WAC104 is equipped with four Ethernet ports. WAC104 AP operates in standalone mode with an intuitive user interface and a set of two external antennas. It is perfectly positioned for customers demanding high throughput, ultra -superior performance, and extensive coverage deployment for Small and Home Office environments.
  • Enhanced connectivity
    With dual-band support, the NETGEAR WAC104 offers Wi-Fi bands of 2.4 GHz and 5 GHz, ensuring a more stable and faster wireless connection. This flexibility allows for less congested networking, providing a smoother online experience for video streaming, gaming, and web browsing.
  • Robust security
    The NETGEAR WAC104 is equipped with multiple encryption algorithms including WEP, WPA-PSK, and WPA2-PSK, alongside features like Access Control List (ACL) support and MAC address filtering. This comprehensive suite of security features ensures that your network remains protected against unauthorized access and data breaches.
  • Versatile performance
    Featuring support for multiple IEEE standards including 802.11a, 802.11ac, 802.11b, 802.11e, 802.11g, and 802.11n (draft 2.0), the WAC104 is designed to deliver reliable wireless performance. Its capacity to handle up to 128 clients makes it an ideal choice for businesses looking for a scalable and efficient networking solution.
NETGEAR WAC104 - radio access point - Wi-Fi 5
Radio access point
External
United Kingdom
Ports Qty
4
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of clients: 128
23.965 cm x 18.145 cm x 4.06 cm
385 g
3-year warranty
Radio access point
23.965 cm
18.145 cm
4.06 cm
385 g
United Kingdom
External
Ports Qty
4
Wireless
Data Transfer Rate
1.2 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless, WPS
Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), wireless bridge mode, SOHO (Small Office/Home Office)
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
Basic Service Set Identifier (BSSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac
Aerial
Antenna
External detachable
Gain Level
3 dBi
4 x 1000Base-T - RJ-45
1 x network cable
MTBF
100,000 hours
EN 60950
External power adapter
8.1 watt
Limited warranty - 3 years
10 - 90%
