NetGear Universal WiFi Range Extender
Quicklinx: 7VJPWS00 Mfr#: WN3000RP-100UKS
  • IEEE 802.11n
The NETGEAR Universal WiFi Range Extender effectively doubles the operating distance of your entire wireless network and conveniently avoids additional need for power cables or device clutter on your office desk or home theater. WN3000RP extends your wireless network to include the area outside the range of your existing wireless router by overcoming obstacles and enhancing overall network signal quality, giving you the freedom to roam anywhere in the house and access Internet without worrying about coverage. The product was specifically designed to be plugged into an electrical outlet, and blends in nicely with any surrounding. It is compatible with wireless b/g/n routers, gateways and Internet service provider devices.
  • Extend network
    Extend Internet access throughout your home for wireless devices like iPads, iPods, laptops, smart phones, game consoles and TVs.
  • Enhance existing equipment
    Keep your current equipment and improve coverage to eliminate wireless "dead zones".
  • Plug-and-Play
    It sets up in minutes, no need to insert a CD or plug in Ethernet cables.
  • Push 'N' connect
    Push 'N' connect using Wi-Fi Protected Setup (WPS) connects computers and/or routers to the extender quickly and securely.
  • Optimal coverage
    Link-rate LED locates the best placement spot to provide optimal wireless coverage.
  • Compatible
    It works with any wireless b/g/n router or gateway from NETGEAR and other brands.
  • Superior security
    It works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP.
  • Connect
    Ethernet port allows the extender to function as a bridge to connect to home theater devices.
NETGEAR WN3000RP Universal WiFi Range Extender - Wi-Fi range extender - Wi-Fi
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7
11.2 cm x 7.4 cm x 4.5 cm
245 g
11.2 cm
7.4 cm
4.5 cm
245 g
United Kingdom
External
Wireless
Frequency Band
2.4 GHz
Repeating mode, Wi-Fi Protected Setup (WPS), wireless bridge mode, Push ā€˜N’ Connect button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45
RoHS, WEEE, CEC
Internal power supply
