NETGEAR Universal WiFi Internet Adapter
Quicklinx: 72RFWS00 Mfr#: WNCE2001-100UKS $
  • IEEE 802.11n
Wirelessly connect devices to your Home Entertainment Network
The NETGEAR Universal Wifi Internet Adapter wirelessly connects networked home theater devices such as Xbox 360®, PS3™, Blu-ray player, and Internet TVs to your home network. Being universal, it works with any network enabled device, eliminating the need to buy separate Wi-Fi adapters for each type of device. It is powered by any USB port, avoiding the use of an additional power outlet. Using this adapter clears the clutter of long, tangled cables. It gives you the freedom to place your home entertainment center anywhere and still connect to the Internet. The compact design enables placement on your HDTV*.
*For best performance place adapter in front or to side of television.
  • Connects HDTVs, game consoles, and Blu-ray players to the Internet
  • Connects any device with a network port to existing Home Wireless Network
  • Wirelessly connects networked home theater devices to your home network
  • Universal--works with any network enabled device. No need to buy a Wi-Fi adapter that only works with one type of device
  • Avoid long stringing cables. Freedom to place your home entertainment center anywhere and still connect to the Internet
  • Option to power by USB port means no exposed wire hanging from the TV
NETGEAR WNCE2001 - bridge - 802.11b/g/n - desktop
Bridge
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Wi-Fi Protected Setup (WPS)
8.1 cm x 6.2 cm x 1.8 cm
60 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7
United Kingdom
Bridge
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Status Indicators
Power, link/activity
1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A (power only)
Aerial
Aerial
Internal
External power adapter
1 x network cable , 1 x USB power cable
United Kingdom
8.1 cm
6.2 cm
1.8 cm
60 g
