NETGEAR Tri-Band WiFi Gigabit Router
Quicklinx: D9QQWS00 Mfr#: R8000P-100EUS
  • IEEE 802.11n
£200.66 ex VAT
£240.79 inc VAT
There's never been Wi-Fi like it. The Nighthawk X6 AC3200 Router with breakthrough Tri-Band Wi-Fi technology was built to connect to each and every device in your home - automatically and simultaneously. Laptops, tablets, phones, TVs, game consoles, music streamers, cameras - if it's Wi-Fi enabled, it's X6 accelerated. A powerful combination of features - wireless speed of up to 3.2 Gbps, 3 Wi-Fi bands, Smart Connect intelligence, and Dynamic QoS - guarantees every device is assigned the fastest Wi-Fi connection possible and optimized for maximum speed. Using Amazon Alexa, control your home network with voice commands.
  • Robust connectivity
    With a data transfer rate of 4 Gbps and support for Ethernet, Fast Ethernet, Gigabit Ethernet, and Wi-Fi 5, the NETGEAR Nighthawk X6S ensures a fast and reliable connection for all your devices. Its integrated 4-port switch and dual-band technology cater to a seamless online experience, whether for gaming, streaming, or everyday browsing.
  • Enhanced security
    The NETGEAR Nighthawk X6S comes equipped with advanced security features such as WPA-PSK and WPA2-PSK encryption algorithms, DoS attack prevention, NAT support, and Stateful Packet Inspection (SPI), providing a safe and secure network environment for your family.
  • Innovative features
    Featuring Beamforming+, MU-MIMO technology, and Circle Smart Parental Controls, the NETGEAR Nighthawk X6S delivers a targeted, efficient wireless connection and comprehensive parental control options, making it an ideal choice for modern households.
  • Versatile connectivity options
    With a variety of interfaces including LAN, WAN, USB 2.0, and USB 3.0 ports, the NETGEAR Nighthawk X6S offers flexible connectivity options for a wide range of devices, ensuring that all your peripherals can be easily connected and managed.
  • Powerful performance
    Powered by a 1.8 GHz processor, the NETGEAR Nighthawk X6S is capable of handling high-speed data processing, ensuring smooth and efficient operation even under heavy network traffic conditions.
NETGEAR Nighthawk X6S - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
Data Transfer Rate
4 Gbps
NAT support, SPI, DoS attack prevention, IPv6 support, parental control, firmware upgradable, WPS, FTP server, ReadySHARE, Push ā€˜N’ Connect button, DLNA Media Server, Beamforming+, MU-MIMO technology, Link Aggregation, guest access, Circle Smart Parental Controls
29.55 cm x 22.68 cm x 5.45 cm
1.1 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
4 Gbps
Encryption Algorithm
WPA-PSK, WPA2-PSK
1.8 GHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Status
Line Properties
Line Coding Format
1024 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
6
External power adapter
1 x network cable
Europe
Software Included
NETGEAR Genie
29.55 cm
22.68 cm
5.45 cm
1.1 kg
Technical support - phone consulting - 90 days
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: IEEE 802.11ac
Speed: 4Gbps
Brand: NETGEAR
